    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree365Likes
Old 07-08-2016, 06:52 PM   #1261
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
Didn't see this can you use a shorty pack in the b6. I didn't read where you can or can't use it just want to make sure..
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 07-08-2016, 07:23 PM   #1262
For sure Shorty batteries are used in the B6 series.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 07-08-2016, 08:06 PM   #1263
Just was making sure Thanks for the input..
Old 07-09-2016, 07:10 AM   #1264
I received my B6 a few days ago and did most of the build last night, I have noticed loads of mistakes in the manual! I also had some bags with the wrong size screws in!
Love the car though can't wait to finish it and run it Tuesday, I have been running a Centro C4.2 and I'm hoping to notice an improvement with the B6
Lozi10 is offline   Reply With Quote
Old 07-09-2016, 07:11 AM   #1265
Suspended
Trader Rating: 61 (100%+)
No one's perfect.
'cept me.
Just kidding.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-09-2016, 08:56 AM   #1266
If you guys need B6/B6D parts compatibility
https://www.rcten.com/threads/b5-b6-...ty-list.20367/
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 07-09-2016, 09:51 AM   #1267
PolarRoller's Avatar
I'm trying to prioritize my list of upgrades/aftermarket parts that I want for my B6D. Can't afford them all at once. I'm running stock on a mid to high traction track. I've got the titanium screw kit from AE at the top of my list because i can't figure any circumstance in which i wouldn't want a lower center of gravity. I looked at all the aftermarket parts Buddha posted in the beginning of the thread. Is there another part i might benefit more from in the beginning?
PolarRoller is offline   Reply With Quote
Old 07-09-2016, 10:06 AM   #1268
suby723's Avatar
Trader Rating: 21 (100%+)
I would get the titanium front axles, aluminum D hanger with inserts and hard front and rear arms.
suby723 is offline   Reply With Quote
Old 07-09-2016, 10:28 AM   #1269
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Initially the part you might want to consider is the aluminum D Block. Allows you to use the inserts and opens up more tuning possibilities.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-09-2016, 10:51 AM   #1270
Suspended
I completely disagree on the Ti axles. They're heavier than the stock axles.
I agree on the Aluminium D mount.
I also always suggest pucks if you're running indoor.
Old 07-09-2016, 12:39 PM   #1271
Thanks for the input y'all. I had the MIP pucks high on my list. Combine those with the the MIP bi-metal diff and it sounds like you could cut the rotating mass way down. I'll probably put those two at the top of my list now. Could one of you post a link to the aluminum D Mount you're referring to?
Old 07-09-2016, 12:49 PM   #1272
suby723's Avatar
https://www.amainhobbies.com/team-as...c91688/p507425
https://www.amainhobbies.com/team-as...c92014/p507476
Old 07-09-2016, 02:25 PM   #1273
1spunspur's Avatar
Great advertising, RCBuddha. I'm assuming you work for A-E?
P./
1spunspur is offline   Reply With Quote
Old 07-09-2016, 03:30 PM   #1274
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Default Aluminum parts
Other than the shocks and motor platedoes the car come with any aluminum goodies, or is everything plastic?
VA Beach
F18engineguy is offline   Reply With Quote
Old 07-09-2016, 03:45 PM   #1275
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Rear C mount, rear camber block, front axles, rear clamping hexes...
https://www.teamassociated.com/news/...b6d_team_kits_
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
aeRayls
