    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 07-08-2016, 02:17 PM   #1246
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Wildcat1971 View Post
Brent commented today that the AE horn was a tad bit tall and would prevent full left and right. with that in mind, the exotek is .5mm shorter, I believe. But you might need a ball stud washer or 3 to get the geometry correct.
Ehh, wasn't he talking about the drag length, not the horn?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-08-2016, 02:25 PM   #1247
Gigasipke's Avatar
I pre-ordered May 10th and today Tower picked and packed my B6D. I was worried because yesterday it said arrival would be Early August. So exciting.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 07-08-2016, 02:28 PM   #1248
Yeah, that is what I was going to try.
40yoCaliRacer is offline   Reply With Quote
Old 07-08-2016, 02:48 PM   #1249
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I misread which ball stud he was referring to. He referenced servo horns, servos and other tolerances as well. In any case, I have an exotek horn, and I plan to try it out. I doubt .5mm will be a deal killer, but We will see.
I have also noticed that some of my servos seem to go further left and right than others. That could come into play with the issue Brent ran into as well.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-08-2016, 02:49 PM   #1250
Weekend fun!
[IMG][/IMG]
Sean B. is offline   Reply With Quote
Old 07-08-2016, 02:51 PM   #1251
lol, I guess your LHS gave AE the finger on their release. How very European/Asian of them grats.
Old 07-08-2016, 02:54 PM   #1252
He didn't say anything about needing to hold it back.
And I wasn't asking lol!
Old 07-08-2016, 02:56 PM   #1253
lol, get to building. We expect all the info you can dish....not much else to do what we all wait...
Old 07-08-2016, 03:07 PM   #1254
lbckevin's Avatar
Trader Rating: 91 (99%+)
The Exotek servo horn works just fine. Jason Snyder broke the stock one when he forgot to loc tite the screw. He bought the Exotek in the OCRC hobby shop and it worked just fine.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 07-08-2016, 03:10 PM   #1255
lbckevin's Avatar
Just checked on Tower Hobbies. Mine shipped and delivery is scheduled to arrive on Monday.
Kevin Smith
Old 07-08-2016, 03:11 PM   #1256
Get my B6 on Monday from LHS.
sgtlt is offline   Reply With Quote
Old 07-08-2016, 03:12 PM   #1257
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Seems like you got one of the lucky c/s people that worked your order. I know a lot of us were told they couldn't ship until Monday...
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-08-2016, 03:26 PM   #1258
lbckevin's Avatar
Hopefully its true. The tracking number doesn't work yet.
Kevin Smith
Old 07-08-2016, 03:51 PM   #1259
Super Moderator
Meh....you can wait til Tuesday
Old 07-08-2016, 05:22 PM   #1260
RCBuddha's Avatar
Trader Rating: 35 (100%+)
nm...looks like a mod took care of it.
RCBuddha is offline   Reply With Quote
