    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree361Likes
Old 07-08-2016, 10:40 AM   #1231
carbons2k's Avatar
Trader Rating: 21 (92%+)
Are the shock bodies on the B6 the same size as the B5m? I have an extra set of Kashimas that I want to use!
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 07-08-2016, 10:45 AM   #1232
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
For the B6 line of cars the rear shock body is only 27.5mm which is part number 91577. The fronts are the same.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 07-08-2016, 10:53 AM   #1233
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
You can utilize the long B6 rear tower and take advantage of the longer b5m rear shocks.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-08-2016, 10:54 AM   #1234
For those of you asking about longer shocks in the rear.... If you add 30mm shocks to a b6d even with a lay down you literately will be driving your b5m with a lay down box and i find it hilarious that all these mods just make the b6d more and more like the b5m
dsms4ever is offline   Reply With Quote
Old 07-08-2016, 10:57 AM   #1235
Finalist's Avatar
Nope.
You are missing numerous differences. I'll start witht the reverse steering rack, weight bias, shock cups, axel height... You can google the rest.
Finalist is offline   Reply With Quote
Old 07-08-2016, 10:58 AM   #1236
Finalist's Avatar
Brent Thiekle just posted this:
"#B6Tip for your @teamassociatedrc #B6 or #B6D. If you're not able to get full throw to the right, this ballstud may be too high. With all the different servos, servo horns and tolerance build-up, the articulation of the drag link may be the limiting factor.
The kit calls for 1mm here, but I had to go to 0 in order to get full throw."
Follow him in FB for a pic.
Old 07-08-2016, 11:25 AM   #1237
Kegman21's Avatar
My car and parts are starting so show up on my cc. Now 20 questions from my wife.
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Old 07-08-2016, 11:44 AM   #1238
celt's Avatar
Yeah, uh, tell her you're buying them for me...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-08-2016, 12:46 PM   #1239
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Contacted Amain and my B6D will be mailed out on Monday. now i can sleep at night....
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-08-2016, 01:33 PM   #1240
Suspended
Trader Rating: 61 (100%+)
Stickit1 has chassis protectors ready to go.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-08-2016, 01:41 PM   #1241
Since the Wiki has a link showing the B5M Exotech servo arm for the B6, one could assume that part is transferable?
40yoCaliRacer is offline   Reply With Quote
Old 07-08-2016, 01:45 PM   #1242
Suspended
NO.
That needs to be updated. The OEM AE horn has a significant raised portion where the ball stud bolts on.
I'm sure you could make it work, but just buy the OEM piece.
Old 07-08-2016, 01:50 PM   #1243
Originally Posted by Socket View Post
NO.
Yeah, at first glance, the Exotek doesn't appear raised as much. Guess I can do a side by side next week.
Old 07-08-2016, 02:01 PM   #1244
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Brent commented today that the AE horn was a tad bit tall and would prevent full left and right. with that in mind, the exotek is .5mm shorter, I believe. But you might need a ball stud washer or 3 to get the geometry correct.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-08-2016, 02:04 PM   #1245
On the way to get my 6D from my lhs
Sean B. is offline   Reply With Quote
