    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree360Likes
Old 07-06-2016, 12:11 PM   #1111
DRJVogel's Avatar
After reading all this, I must say that all you guys are hopeless RC addicts . . . just like me.
near Grass Valley, CA --- let's bash
DRJVogel is offline   Reply With Quote
Old 07-06-2016, 12:17 PM   #1112
ryan432greening's Avatar
How could there possibly be 75 pages of information already? Almost none of you have kits that's a lot of excitement and anticipation.
B-Main Racing
TLR 22 4.0, TLR 22 3.0, 22-4 2.0, 8ight-E 4.0
ryan432greening is offline   Reply With Quote
Old 07-06-2016, 12:21 PM   #1113
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Originally Posted by Finalist View Post
So given the July 7th date that has been posted twice does that mean ae is sending some kits out to be sold tomorrownin the USA?
...something is making Amain think they would have stock tomorrow.
From what I have heard...no shops in the USA can sell until the 11th. I wouldn't worry about what amain posts because I honestly think they have no clue when they are getting them. It would make sense for them to be received Thursday / Friday so they can be ready to ship on Monday though.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-06-2016, 12:26 PM   #1114
skrichter's Avatar
Send a message via AIM to skrichter
Amain updated their date to 7/11
https://www.amainhobbies.com/team-as...c90012/p501377
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 07-06-2016, 12:26 PM   #1115
Silverstonev8's Avatar
Originally Posted by BRSracing View Post
I had one on backorder from two months ago, i see it did not ship. did you preorder the plate?
It showed in stock limited quantities. So I placed my order and I checked stock again. It showed out of stock.
Silverstonev8 is offline   Reply With Quote
Old 07-06-2016, 12:27 PM   #1116
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
That would be lame.....since the rest of the work is selling the kits....
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-06-2016, 12:27 PM   #1117
celt's Avatar
Whuuut?
"Yeah dude...see that stack of B6/B6D kits? Can't sell'em to ya, gotta wait until the 11th."
Why do I not see that happening...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-06-2016, 12:28 PM   #1118
fullsyzz's Avatar
Trader Rating: 106 (100%+)
WTF are they doing over there?!? Is Chico high?
LOL.....Generally speaking, yes.
fullsyzz is offline   Reply With Quote
Old 07-06-2016, 12:30 PM   #1119
Super Moderator
Originally Posted by celt View Post
Whuuut?
It's easy to not sell it when the shops wont have them until that date. AE has stock of both kits and parts but have been holding out. Building anticipation for sure...I don't understand the reasoning behind the 11th but it is what it is.
Old 07-06-2016, 12:32 PM   #1120
celt's Avatar
Well that I'll buy Matt - if they don't have the kits to sell...sure.
The two shop owners I know would gladly pass out the kits to customers just to stop the noise.
Stan Garvin
Old 07-06-2016, 12:33 PM   #1121
Jmuck69's Avatar
Trader Rating: 14 (100%+)
11th Release date coincides with the announcement of the new wheeler.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-06-2016, 12:36 PM   #1122
celt's Avatar
Now that would be epic, no?
Stan Garvin
Old 07-06-2016, 12:38 PM   #1123
suby723's Avatar
Trader Rating: 21 (100%+)
Ugh this is seriously messing with my emotions badly!
suby723 is offline   Reply With Quote
Old 07-06-2016, 12:39 PM   #1124
Dude, AE is trolling you hard core, lol
Old 07-06-2016, 12:40 PM   #1125
I am just building the new B44.3 now I bought in November, LOL.
This is like Apple iPhone 4 and other crazy Apple launches. We don't know how many phone units we are getting in. I am not sure we get them on launch day. When is launch day? Just show up everyday until you get one and run around store to store like a silly idiot until you get one.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
