    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 07-04-2016, 12:15 PM   #1066
lbckevin's Avatar
Trader Rating: 91 (99%+)
it goes in just great
I watched Nick Wautlet from AE change the electronics in 5 minutes from his b5m to his new B6d
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 07-04-2016, 12:29 PM   #1067
Thanks ! it looks like it should be.
I will post some video of mine ASAP on indoor clay track
I will do kit setup maybe different oil in front
Dmitri Tech is offline   Reply With Quote
Old 07-05-2016, 08:33 AM   #1068
Does anyone know if a stock b5m body will fit? What about some of the JC or Pro-line ones?
Will b5 chassis protectors fit?
MrLean is offline   Reply With Quote
Old 07-05-2016, 08:36 AM   #1069
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
They do not fit....the front near the servo is wider on the B6. Chassis protectors would probably come close but there would be gaps for sure.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-05-2016, 10:09 AM   #1070
BRSracing's Avatar
Trader Rating: 55 (100%+)
Ready for some.laps.with.the B6!
BRSracing is offline   Reply With Quote
Old 07-05-2016, 10:10 AM   #1071
suby723's Avatar
Trader Rating: 21 (100%+)
It sucks Amain pushed back the arrival date to the 11th!
suby723 is offline   Reply With Quote
Old 07-05-2016, 10:13 AM   #1072
BRSracing's Avatar
From the sounds of it they have changed the date several times. Could be worse like Kyosho fans waiting for a three gear and instead Kyosho brings out a rc surfboard
Old 07-05-2016, 10:17 AM   #1073
Super Moderator
Coordinated release is on the 11th.
Old 07-05-2016, 10:39 AM   #1074
If it's a coordinated release does that mean hobby shops will have them on the 11th?
Sean B. is offline   Reply With Quote
Old 07-05-2016, 10:40 AM   #1075
Super Moderator
As long as they ordered early they should.
Old 07-05-2016, 10:42 AM   #1076
It just means that nobody "should" be selling them before the 11th.
boucher is offline   Reply With Quote
Old 07-05-2016, 01:13 PM   #1077
Suspended
Trader Rating: 61 (100%+)
Except for the shops outside of the USA. Many of them have kits and are actively selling them. Just like the TLR 22 release and the AE rc8b3 release, foreign markets get them before the USA.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-05-2016, 01:43 PM   #1078
BRSracing's Avatar
The B5 as well. I have wondered if maybe when they leave China (if that is where they are made) they make it to distribution centers outside the US first so overseas folks see them a week or so faster. Ports coming into the US likely make it slower too. We will see them soon enough.... Luckily the B5m is likely not much off the performance of the 6.
Old 07-05-2016, 01:47 PM   #1079
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
ThunderTiger (owner of AE) is in Taiwan.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 07-05-2016, 02:37 PM   #1080
AE-Reedy
No kits were shipped direct from over seas.
All B6 kits have to leave from AE in the US.
Sean Cochran is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
germanz28
