    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree325Likes
Old 04-29-2016, 02:06 PM   #91
Johnn27's Avatar
Trader Rating: 71 (100%+)
Thumbs up
Originally Posted by Socket View Post
I'm sure they will. Except it'll come in kit form. You buy the B6D or B6 kit, take off your b5m body, roll the b6d or b6 kit under your body, then put it on. Boom, converted.
LMAO
Johnn27 is offline   Reply With Quote
Old 04-29-2016, 03:32 PM   #92
Trader Rating: 16 (100%+)
I wonder if the new front and rear hubs will fit on the B5M. I have a laydown conversion in it already and if I could adapt the new hubs I'd just keep it for carpet and get a B6D for clay.
MX304 is offline   Reply With Quote
Old 04-29-2016, 03:45 PM   #93
YoG
YoG's Avatar
Yes there is some tires in the works. I think most of the testing has been overseas. This is the Jconcepts carpet tires.
XRAY XB2ce/AE T5M/AE SC5M/HB D413/TEKNO SCT410
http://www.corvictoria.com/
YoG is offline   Reply With Quote
Old 04-29-2016, 03:46 PM   #94
These look really nice. I was expecting a new 4WD to be announced before a B6.
Wheeler26 is offline   Reply With Quote
Old 04-29-2016, 03:58 PM   #95
Originally Posted by 40yoCaliRacer View Post
According to the photos on AE's site, the B6D doesn't use the laydown transmission. The B6D transmission photo looks like the B5Ms to be honest.
Of course the B6D doesn't have the laydown transmission. It is made for dirt.
Old 04-29-2016, 04:07 PM   #96
Thank you for the condescending reply. I'll be sure to know everything about the hobby before I ask another question.
And they both are supposed to be for clay, so that was my next question, which one.
40yoCaliRacer is offline   Reply With Quote
Old 04-29-2016, 04:09 PM   #97
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
You're both new....knock it off. We don't put up with bickering here (usually).
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 04-29-2016, 04:19 PM   #98
The B6D would be what you want for 95% of clay tracks. There are a few stupid high grip clay tracks that have similar grip levels as carpet / astro. That's where the B6 would shine.
Old 04-29-2016, 04:22 PM   #99
Well to be honest if one races on carpet or high bite the B6 looks to be very very good. The key for me besides the laydown tranny are the weights on the chassis. I run mod (6.5T) so extra weight is not such a big issue. My B5M is almost brand new but I will buy the B6 when it is available.
jneg is offline   Reply With Quote
Old 04-29-2016, 04:24 PM   #100
Thanks, around here almost everything is Clay. Honestly, I just bought a B5M and can't make it around the track 3x without crashing, so that is my focus right now. I was just trying to point out that without the laydown transmission, the B5M and B6D don't "appear" that radically different. The B6 (Carpet), though, does.
Old 04-29-2016, 04:30 PM   #101
Agreed, I just looked atthe youtube videos and for carpet and astro the car should be awesome.
Old 04-29-2016, 05:28 PM   #102
3n90t's Avatar
I only have the hopfully new AE 4WD in my budget for this years season. The B44.3 is still a great car, but I might have the get this instead. Haha
AE: B5, B5M, B44.3, B6D, B64D
Tamiya: MF-01X Suzuki Jimny JB23
3n90t is offline   Reply With Quote
Old 04-29-2016, 05:46 PM   #103
JAE
Trader Rating: 28 (100%+)
Default Arrival ETA?
My hobby shop says June? Anyone hear anything else? In any event I may just look for the carpet. To me the Dirt doesn't look a whole lot different
JAE is offline   Reply With Quote
Old 04-29-2016, 06:01 PM   #104
Jmuck69's Avatar
Amain has a date of June 17
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 04-29-2016, 06:20 PM   #105
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
While the front carriers/spindles should bolt up to the b5m the geometry is most likely not the same as it is designed to work with the new steering rack...rear hubs should be good to go.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Braxamus, Lextek
