    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 06-29-2016, 08:30 AM   #1006
SuperRC's Avatar
What is the benifit of the FOX Kashima shock bodies compared to the standard V2 shock bodies?
SS
SuperRC is offline   Reply With Quote
Old 06-29-2016, 08:34 AM   #1007
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
They have a coating that reduces friction. On the track you will most likely not notice any real difference compared to the standard bodies. You can feel a difference in your hands when you take a std body and molded piston and compare it to the kashima body with a machined piston though.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 06-29-2016, 08:37 AM   #1008
It appears the new car will be pretty lightweight right from the box. Looking at Rivkin's and BT's setup sheets from JC Spring Nats, they both ran 50-54g under the battery and still only had car weights of 1540g and 1530g, and that's with the brass C block. This will make the weight plates a pretty useful tuning option.
boucher is offline   Reply With Quote
Old 06-29-2016, 10:55 AM   #1009
onefast8's Avatar
Trader Rating: 41 (100%+)
Are there new shorter rear Kashima bodies?
Jake R.
onefast8 is offline   Reply With Quote
Old 06-29-2016, 11:01 AM   #1010
Rear B6 shock bodies are the same as the T5M fronts. P/N 91577 for the Kashima Coat.
will5879 is offline   Reply With Quote
Old 06-29-2016, 11:17 AM   #1011
Mason's Avatar
Originally Posted by Wildcat1971 View Post
+4 mm trailing
please keep us informed of a 3mm option.
When I watch a 4mm car turn I want to ask the driver if they have a porch to hang that swing on.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 06-29-2016, 11:25 AM   #1012
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Kody said, nothing in planning for a +3 or +2. Something about they will look into later if it is needed.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-29-2016, 12:25 PM   #1013
jordy-15's Avatar
Trader Rating: 17 (100%+)
They are silky smooth
:: Proline :: XRAY :: Muchmore::HEI ::
www.nbhc.com.au
www.rchobbyland.com
www.sydneyrc.com
jordy-15 is offline   Reply With Quote
Old 06-29-2016, 01:57 PM   #1014
Originally Posted by Wardog41 View Post
Anyone that's not a team driver have there b6d or b6 yet?
So a local hobby shop posted today that AE plans for a coordinated July 11th release. Take that with a grain of salt, because everything on the internet is not always true. But...Amain still says July 11th on their site and Tower still says mid July....
Old 06-29-2016, 03:55 PM   #1015
Will be a great stock car then
offroader47 is offline   Reply With Quote
Old 06-29-2016, 04:08 PM   #1016
Funny how an average guy like me can be right. I think the packaging is very time consuming and to be fair like to all hobby shops vs the big online retailers the shipment is set a certain way. Also worldwide launch, so you got to ship those earlier. And we seen the team drivers all look to get their stuff first as well as good quality reviewers in the industry.
Just think about how many kits Tower will get. Probably like 8 to 10 skids of these 2 kits initially. Lots of work.
Maybe I was wrong of the complete kit sealed and on the boat for the 10 day to 2 week ride over to North America. I guess the JConcepts Body add to the kit or just the majority of the parts were shipped and they are bagging them with some items made in the USA which would be nice for once to put it all together.
The world doesn't work on early. Either on time or late. AMain with their July 11 date or Tower with their mid July date (which is the 10th to 20th of the month) is basically pretty right on all along.
Just 1.5 more weeks I guess for you guys. I hope I can sell some older items to get a B6 first as I have a carpet track nearby and I will use the B5M Lite for outdoors for the rest of the season and then grab the B6D also.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 06-29-2016, 07:20 PM   #1017
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Do you guys want me to continue to list all the aftermarket accessories for the B6/B6D on the front page? Or just links to the manufacturer's websites?
I'm wondering if having the list is useful or not.
RCBuddha is offline   Reply With Quote
Old 06-29-2016, 11:01 PM   #1019
What about th accessory and a link? Keep up the good work updating us who can't keep up as often as we would like to!
Slashn77 is offline   Reply With Quote
Old 06-30-2016, 01:15 AM   #1020
Cridd's Avatar
Trader Rating: 16 (100%+)
Links I think would be good and easier.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Currently Active Users Viewing This Thread: 9 (1 members and 8 guests)
Allen Drebi
