    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree326Likes
Old 04-29-2016, 12:22 PM   #76
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by 40yoCaliRacer View Post
According to the photos on AE's site, the B6D doesn't use the laydown transmission. The B6D transmission photo looks like the B5Ms to be honest.
it is not the same as the b5m. both transmissions are new
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-29-2016, 12:44 PM   #77
I guess my point is, the B6 is much more of change compared to the B5M platform, then the B6D is to the B5M.
Seems like you if you drive primarily on Clay (Much of the SoCal circuit), which do you choose? Their little chart has Clay in the middle and shows them both "good" for clay...
40yoCaliRacer is offline   Reply With Quote
Old 04-29-2016, 12:48 PM   #78
neallewis's Avatar
Originally Posted by Rhett McNair View Post
New Jconcepts carpet turf tires
No not at all. They are Schumacher cut staggers in yellow. Hand out tyre for the EOS series.
neallewis is offline   Reply With Quote
Old 04-29-2016, 12:50 PM   #79
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by thefnshow View Post
associad must be sick or something...they usually take forever to come out with a completely new car
They must have extra bills that need paid.
ST Racing Concepts (STRC)
Old 04-29-2016, 12:52 PM   #80
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Are you really gonna debate the tire in the attached photo as being Schumacher?
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 04-29-2016, 01:01 PM   #81
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Do they look like this?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-29-2016, 01:08 PM   #82
There is a 4 gear standup available for the B6D as an option; it's listed on the PDF spec sheet on AE website.
All the EOS pics feature the Schumacher tyres as they're handout at EOS...but I think 'box art' shots feature the new JConcepts tyres?
Be interested to try them when they come out, though currently nothing quite as good as the Schumacher tyres on Astro/Carpet IMO.
andrewcoley is offline   Reply With Quote
Old 04-29-2016, 01:15 PM   #83
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Tranny differences
akura2 is offline   Reply With Quote
Old 04-29-2016, 01:32 PM   #84
gokarter64's Avatar
Interesting in that they went to that larger idler in the b6. I wonder how that will change up the internal ratios
gokarter64 is offline   Reply With Quote
Old 04-29-2016, 01:38 PM   #85
no it wont. it could have 400 teeth and it would be the same
Old 04-29-2016, 01:41 PM   #86
Jmuck69's Avatar
Has no effect. Input shaft and Diff gear determine the ratio
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 04-29-2016, 01:41 PM   #87
SuperBoots's Avatar
Good timing, I was about to pick up a b5m for my first buggy. I'm curious what will be the popular option at my local clay track, sounds like both the b6 and b6d are claimed to work on clay.
-Dan
RC10B4.2, RC10T4, SC10
Find me at T.R.C.R.
SuperBoots is offline   Reply With Quote
Old 04-29-2016, 01:51 PM   #88
The GRP front cut stagger tyre is much nicer to drive on then the Schuey tyre, has a much nicer turn in and general level of grip, the Schuey can be a bit vicious sometimes.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 04-29-2016, 01:53 PM   #89
I plan to get the B6D and then pickup the laydown transmission parts for tuning. The parts dont cost much.
Old 04-29-2016, 02:01 PM   #90
neallewis's Avatar
I'm talking about tyres on the car today at EOS. No idea what those^ are, they look s#@t.
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
shdwboxn
