    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 06-23-2016, 08:31 AM   #856
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Mason View Post
Alright, now let's get down to the brass tacks.. Are parts only production runs occurring yet? Will parts be available in the hobby shops when the kits arrive? As we all know every car release of every kind has the same problem. Joe HotShoe has to buy 2 kits to have parts on hand for the first month in case he breaks an arm, tower, etc. because even with LHS' having items on order or even backorder they are not available. John Newbie buys a kit, comes out to the track and ends his race day before running a qualifier because he broke in practice. What good does it do me to have a car, break something, and then not be able to replace it? This is the Number 1 reason why I never pre-order a kit or heck, even consider buying one until I see parts on the wall. So have we changed our ways this time around?
You haven't been watching AE's website, have you?
Parts have started to pop up...
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 06-23-2016, 09:45 AM   #857
I drove my b5m for a year without breaking anything but wings...learn how to drive and it will save you a lot of wasted money and time on replacement parts....
dsms4ever is offline   Reply With Quote
Old 06-23-2016, 10:04 AM   #858
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
if my b6 breaks, I will finish the day with my kids b5m
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-23-2016, 11:32 AM   #859
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
True, but you can be the best driver in the world but things happen beyond your control and well...*$%% happens.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-23-2016, 11:55 AM   #860
Not trying to tote my ability to drive... Because I'm not an expert just wanted to point out their durability!
Excited for the b6, it's coming quick...... Should be interesting to compare it to the b5m with 3 gear lay down. Because in my eyes the only true game changer will be the rear shocks in front of rear arms.
Old 06-23-2016, 11:57 AM   #861
IMO, the b6 has a lot of small things that are nice. Most of which wont effect lap times.
Old 06-23-2016, 12:15 PM   #862
That's the exact way I look view it because the b5m wasn't "broke" so don't fix it.. Not too much anyway just enough to keep evolving. I think it will be a very nice kit and look forward to picking up one up in a special model like I did with the factory lite and I think it will be a very popular car and a very winning car at the top levels for the next couple years again
Slashn77 is offline   Reply With Quote
Old 06-23-2016, 12:34 PM   #863
Dont hold your breath for a special model. Looking at the b6, makes me wonder if there will be one. They may be taking the route of Kyosho and TLR. The b6 has a lot of option parts on it. In the past AE made a "basic" car, then released a FT a year later. But the B6 comes with more upgrades than the B5M Lite did. So, unsure there will be a B6 FT car next year. Even the B6 chassis is already lightened.
Old 06-23-2016, 12:37 PM   #864
Suspended
Hard parts.
Old 06-23-2016, 01:16 PM   #865
Super Moderator
Kraig's Avatar
Understand where you are coming from.
If you look, there are molded plastic pieces for the steering bell-cranks and arms. Even though the current pictures show they are aluminum. I can't imagine the kit having them. Or maybe a representative said yes it is coming with aluminum pieces and if so that shoots my theory.
Old 06-23-2016, 01:29 PM   #866
sure, AE could put all the alum parts on it and call it a FT. I just dont think they will. I think it comes with the critical items already. The rest is option parts. My point was the B5M came out after a year, and the B6 is as good or better equipped. If I were AE, I would the the car alone until something changes in the market, like the whole laydown/mm thing. Alum hubs and bell cranks should be left as option parts.
Old 06-23-2016, 01:29 PM   #867
Originally Posted by Socket View Post
Hard parts.
Those are and should be option parts. As they are very situational and less durable.
Old 06-23-2016, 02:14 PM   #868
AE-Reedy
Originally Posted by 190mph View Post
Yes talented multi-class sponsored RC racer that runs the Reedy division?
Have the manuals up tomorrow by 6PM EST and I will believe boys.
I think you are giving me too much credit.
I don't think the manual will go up today as some people involved are off. But it will not be much longer.
Sean Cochran is offline   Reply With Quote
Old 06-23-2016, 02:28 PM   #869
you let people take off work during a major release...shame shame
Old 06-23-2016, 02:38 PM   #870
Mason's Avatar
nope.
that's great. I'll believe it when they hit the walls here, especially since we're 80% AE as far as racers go.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
the resistance, Tijuana_Taxi
