    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree361Likes
Old 06-15-2016, 05:05 AM   #766
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Wildcat1971 View Post
I wonder if it was an accident. maybe they were putting inventory in the system for release, but didnt mean to put on the website.
It shipped and will receive them Friday.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 06-15-2016, 09:45 AM   #767
Proline is about to release a body for the car also
Rhett McNair is offline   Reply With Quote
Old 06-15-2016, 09:56 AM   #768
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
NICE. getting the body painted before the car arrives is always nice. No need for a rush spray bomb job.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-15-2016, 09:57 AM   #769
If tower and Amain hobbies are going to get them on July 11th....how long would it take to ship over from overseas? I wanna see that manual. I also want see how much more on power steering the B6 has on turf than the freaking B5M with a stand up 4 gear!!
dsms4ever is offline   Reply With Quote
Old 06-15-2016, 10:43 AM   #770
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
You want on power steering, reduce front droop. Why are you running a 4 gear on turf?
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 06-15-2016, 01:50 PM   #771
I'm running the b5 front arms and tower with brass inserts to raise front axle height.
The 4 gear is in there because I sold my 3 gear to make a deal happen on another b5m and I was planning buy the 3 gear lay down but then I'd need a new body and it's just not cost effective when the b6 is pre ordered.
I expect the b6 to be race ready... Which would surprise me with plastic hubs, but we'll see.
Old 06-15-2016, 01:50 PM   #772
With the b6 gullwings doesn't that increase droop??
Old 06-15-2016, 03:06 PM   #773
eper's Avatar
yes but without changing roll center.just makes the car smoother to drive fast on turf. less twitchy
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 06-15-2016, 11:20 PM   #774
Will they release the body before he car is available?
Mxer210 is offline   Reply With Quote
Old 06-15-2016, 11:40 PM   #775
rvrslt1's Avatar
Trader Rating: 27 (100%+)
So.... If I only run on clay high bite track I would want the B6D and then add the lay down trans correct? Now I am running the B5M with 3 gear and B5 flat arms and tower. Would like to order the correct car. Now the next question is how long before they have the parts out to put the lay down trans into the B6D??
rvrslt1 is online now   Reply With Quote
Old 06-16-2016, 01:11 AM   #776
BRSracing's Avatar
Trader Rating: 55 (100%+)
Originally Posted by celt View Post
Is it carbon? I'm a sucker for carbon...
yes it is
BRSracing is offline   Reply With Quote
Old 06-16-2016, 01:27 AM   #777
Correct, you should get the B6D because it will only cost about $35 to convert your transmission to laydown (instead of Converting a B6 to a dirt car, you'd need a ball diff, front tower, front arms aprox. $80) To convert your dirt car to laydown you will need:
Part #: 91708 (Laydown gear box $8.99)
Part #: 91709 (Chassis Brace, aka waterfall $8.99)
Part #: 91715 (Laydown motor plate $13.99)
Part #: 91716 (Laydown 39t idler gear $5.99)
I also recommend you run a brass C mount if you're going to run a laydown on clay; Part #: 91716
And the parts should be available before or by the time the car comes out, they are already getting some stuff in stock. But my guess is the parts will sell out fast because everyone will be wanting the same parts at first. So keep an eye on the website and order the stuff you want when you see it in stock.
Old 06-16-2016, 04:57 AM   #778
Yes, the official announcement and pics will be next week sometime. They also will have a black anodized front wing mount and wing set.
Predator Body #3475-00
Wing and Mount #6281-01
Old 06-16-2016, 02:00 PM   #779
MOmo's Avatar
Its rumored that a certain Engineer from AE will be visiting our local track since he is going to be home visiting family and that he packed a B6 with him and will be testing on our indoor Turf/Carpet tracks..........
Can't wait to see what all the Hype is about....
RACE CARS: B44.1, RC8.2E FT, RC8TE ME, YZ-2T, D08
RADIO: Futaba 4PKS/3PKS. BATTERY: Venom
ESC: SpeedPassion. MOTORS: SpeedPassion / Venom
"Im not a racer, but I play one on the Internet"
MOmo is offline   Reply With Quote
Old 06-16-2016, 02:02 PM   #780
Jmuck69's Avatar
https://www.teamassociated.com/news/...rc10b6_and_b6d
Now you can use the B5 rear shocks.
B6D | B64D
Currently Active Users Viewing This Thread: 11 (2 members and 9 guests)
DJH, RC10Nick
