    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 06-13-2016, 07:24 AM   #751
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Just noticed the new wiki on the front page, what things would you guys like to see in it?
RCBuddha is offline   Reply With Quote
Old 06-13-2016, 07:41 AM   #752
Super Moderator
Trader Rating: 17 (100%+)
First off, you do an excellent job on the first page. Just had to get that out of the way
I was just about to post this below LOL
In case you guys didn't notice it, I've created the Wiki for this thread. Similar to the old '1st page' posts, but now it appears at the top of every page.
Anyone can edit it, but just keep in mind that EVERY edit is recorded and we can see who did it. Abusing it will result in a forum ban.
My suggestion is that if you have a new item you want to post on the Wiki and aren't sure if you should, just post it in the normal part of the thread and ask. If you see a majority in agreement, post it.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 06-14-2016, 12:51 PM   #753
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Just ordered (2) B6 bodies off AE's website...they show "low inventory"
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 06-14-2016, 01:08 PM   #754
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
hahaha, nice. off to the painter?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-14-2016, 01:14 PM   #755
Jmuck69's Avatar
yup! it indicates "out of stock" already
B6D | B64D
Old 06-14-2016, 01:31 PM   #756
so, will they ship the body or cancel your order....
Old 06-14-2016, 01:39 PM   #757
Jmuck69's Avatar
It should ship, have not received a cancel order yet. it was low inventory when i placed the order then 15mins later, out.
B6D | B64D
Old 06-14-2016, 01:53 PM   #758
I wonder if it was an accident. maybe they were putting inventory in the system for release, but didnt mean to put on the website.
Old 06-14-2016, 01:54 PM   #759
curious to see if you get it before the release of the car.
Old 06-14-2016, 01:56 PM   #760
Jmuck69's Avatar
if they cancel it then it's no big deal to me.
B6D | B64D
Old 06-14-2016, 02:06 PM   #761
Mason's Avatar
These are the white knuckle moments of I.T. That is the free reign of people to edit whatever they see fit. Yippiekaya!
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 06-14-2016, 03:02 PM   #762
BRSracing's Avatar
Trader Rating: 55 (100%+)
when they released the B5 I ordered a bunch of parts before I had the car. Then they took all the parts offline but i got mine well before the car. I did not use really any of the parts i ordered because the car never broke! A body early would be super cool though! A few days back someone mentioned outdrives were in stock. AE and TLR have done good lately with new releases and parts at the same time. Years ago one would buy a new car and there would be no parts available to fix anything that broke.
BRSracing is offline   Reply With Quote
Old 06-14-2016, 03:05 PM   #763
BRSracing's Avatar
so who is going to order a Jconcept setup board? $220.00 just curious seems kind of out there to spend that kind of money on one.
Old 06-14-2016, 03:27 PM   #764
celt's Avatar
Is it carbon? I'm a sucker for carbon...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 06-14-2016, 07:23 PM   #765
RCBuddha's Avatar
Hey Bob/Racer/Cap, I tried to edit the wiki and kept getting database errors..
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
