    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree372Likes
Old 10-17-2017, 10:12 AM   #7471
Trader Rating: 24 (100%+)
Originally Posted by johnnyshore View Post
Tried searching, but didn't see what I was looking for...
With the revised battery strap in the B6 having a center hole for what appears to be a link mount to the trans, does AE sell a specific part to utilize this?
I haven't seen a revised battery Strap. Got a link? Photo?
Associated B6 x2
Associated B64D
Associated B64
Associated T5M
Scott R is offline   Reply With Quote
Old 10-17-2017, 12:02 PM   #7472
aeRayls's Avatar
Not currently but you use the same length turnbuckle as the rest of the car uses. Then put shocks ends on it.
aeRayls is offline   Reply With Quote
Old 10-17-2017, 02:03 PM   #7473
monkeyracing's Avatar
Any advantages in this, or is it just a new, shiny thing?
monkeyracing is offline   Reply With Quote
Old 10-17-2017, 06:09 PM   #7474
Are you sure that's an AE part? There are multiple aftermarket companies offering what you describe.
mx836 is offline   Reply With Quote
Old 10-17-2017, 06:11 PM   #7475
I think it is used in place of waterfall brace on laydown trans to facilitate a more rearward mounted lipo in lower grip conditions. I guess it would add some more flex as well
JLinney is offline   Reply With Quote
Old 10-17-2017, 06:45 PM   #7476
aeRayls's Avatar
It allows you to remove the waterfall and adjust the lipo much further back.
There are aftermarket companies that offer straps like this but ae has revised the plastic kit brace.
Old 10-17-2017, 07:05 PM   #7477
Big_Show's Avatar
Would that work on 3 gear stand up also?
RC10B6D/RC10T5M/RC10SC5M
Big_Show is offline   Reply With Quote
Old 10-17-2017, 07:13 PM   #7478
lbckevin's Avatar
Trader Rating: 91 (99%+)
Schelle Racing makes a great one..Its a lipo brace and turnbuckle.
RCW likes this.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-17-2017, 07:14 PM   #7479
lbckevin's Avatar
Yes, the Schelle brace will work.
Big_Show likes this.
Kevin Smith
Old 10-17-2017, 11:39 PM   #7480
Hadnít thought of that. Smart. I like the look of the Exotek version.
My stock brace never holds the battery well enough. Always seems to slide forward a bit.
Old 10-18-2017, 02:18 AM   #7481
whats the smallest pinion count you can run with a 69t spur? im changing from mod to 17.5. on my track the gearing guide is bang on for my track at 24-25/78 for the 10.5 .
im looking at going with a fantom v3 motor but the gearing suggestions from some on 17.5 facebook page are waaay different like 28/72 or even 34/69.
anyone running a V3 fantom motor?? any suggestions on gearing taking in to account the suggested gearing was pretty bang on in the book for 10.5?
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Old 10-18-2017, 10:15 AM   #7482
jtodd57's Avatar
does the revised kit battery hold-down as mentioned earlier have a AE part number ????? Haven't seen anything about this update
Jeff Todd-Jackson, MI
Fantom Motors & Killer Voltz Batteries--ProLine Racing--Schelle Racing Innovations
Team Associated B6D/B6
Salvas MudBoss spec oval racer
jtodd57 is offline   Reply With Quote
Old 10-18-2017, 10:21 AM   #7483
31/69 is a good starting point for 17.5 but you can probably go up to a 33 with that motor
roysays is offline   Reply With Quote
Old 10-18-2017, 11:21 AM   #7484
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
How? There are posts on the stock brace that would keep the battery from moving anywhere...
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-18-2017, 02:37 PM   #7485
Donít know how, but the battery is able to put enough pressure on those posts to bend the front edge of the brace upwards enough for the pack to slide forwards.
I canít see how Iíd be able to crank it down any more than I have. Itís already at the verge of bending the mounting ears off. Iíve got the foam underneath to help as well.
Iím fairly sure of this posts were a little longer, or the brace made of a stiffer plastic, it would be better.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
