    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree361Likes
Old 06-01-2016, 09:49 AM   #676
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by weedsnager View Post
Thanks for all your help....
I'll be using a spektrum radio and a Blackbox 800Z Zero-Timing ESC
Voltage Input: 7.4V, 2S LiPo
On Resistance: 0.0004
Continuous Current: 80A
Dimensions: 1.6 x 1.2" 0.74" (40.2 x 31.0 x 18.8mm)
Weight: 1.3oz (37g)
Motor Limit: 10.5T
SBEC: 6.0V/3A
A savox 1258 will be fine for you. they are cheap and pretty decent for 1/10 buggy.
https://www.amainhobbies.com/savox-s...1258tg/p183316
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-01-2016, 10:09 AM   #677
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Originally Posted by Kraig View Post
I primarily look at the speed, torque and the voltage that the servo is rated at. Right now, I am at least looking for a speed of .10 seconds, torque of 100 ounce inches, at 6 volts. I say 6 volts because that is what my speed control b.e.c. is supposed to be able to supply.
Some speed controls only supply 5 volts and some receivers can't handle voltages above 6, but they are getting to be few and far between.
If you can share what radio system and speed control you are using we can let you know if there might be compatibility issues.
I have used Xpert servos with great success. If you want a shorty, the Pi-3402 ($105) is a great choice. If you want a full size, the Si-4431 ($80) is a perfect fit. Both operate faster than the speed and have more torque than you are asking at 6V. I find they draw very little power over a run.
I ran these before I was sponsored because I was tired of Savox needing high voltage/amperage and the price range of the KO servos.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 06-01-2016, 10:55 AM   #678
5tone's Avatar
plus one for an xpert servo
pretty high quality en perf. for the half price of a fut. or ko.
...and not noisy...
5tone is offline   Reply With Quote
Old 06-01-2016, 12:24 PM   #679
I'm looking at the D version, for some light racing. I don't need anything fancy, just the most reliable servo that won't break the bank, I'd like to stay under $100
Ryan Cavalieri is running the Savox 1258t, a $60 servo. So thats a pretty cheap servo that can be used at the highest level
mgers75 is offline   Reply With Quote
Old 06-01-2016, 12:47 PM   #680
And to anyone who says it doesn't work with Spektrum: I use it that way. The only problem I can confirm is when using cheap ESC's!
man1ac is offline   Reply With Quote
Old 06-01-2016, 07:34 PM   #681
I have a savox in another car with spektrum gear, works fine with a glitch buster....thanks for the recommendations guys
weedsnager is offline   Reply With Quote
Old 06-01-2016, 07:48 PM   #682
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Originally Posted by boucher View Post
Could we also get the setup database added to the first page? Not much there now, obviously.
http://site.petitrc.com/setup/associ...tedRC10B6.html
added
RCBuddha is offline   Reply With Quote
Old 06-01-2016, 07:52 PM   #683
RCBuddha's Avatar
I'm a fan of the XP 1015 and 1013; but the Reedy Servos seem to priced comparably. Protek is next on my list to try.
Old 06-01-2016, 10:32 PM   #684
Whig protek? The 160ss?
Slashn77 is offline   Reply With Quote
Old 06-02-2016, 03:50 AM   #685
xyzracer's Avatar
I run a protek 130ss in a couple of my cars and it's awesome but you need a stout BEC to run it because it draws such a high current. I run these with my tekin gen 2s because of the 5 amp BECs. I run savox 1258 or spektrum 6040/6240 with my hobbywing escs with no problems as well. All using airtronics radios.
xyzracer is offline   Reply With Quote
Old 06-02-2016, 06:04 AM   #686
elex300's Avatar
Trader Rating: 102 (100%+)
Originally Posted by dustneyes View Post
I realize that there is no gear cover for the lay-down transmission because it was born from the carpet world, but those that will be running it in there B6D... Will there be a gear cover for the spur and pinion for those running in the dirt?
The body doesnt cover the spur gearon a traditional stand up transmission so you use a gear cover. On the laydown transmission the body is designed to cover everything. No need to cover it twice.
elex300 is offline   Reply With Quote
Old 06-02-2016, 07:30 AM   #687
I like the specs on the 160T. Good speed and torque.
Old 06-02-2016, 11:03 AM   #688
Yeah me too I just would never need that much torque in a 1/10 scale
Old 06-02-2016, 11:31 AM   #689
and you would need the speed more?
Old 06-02-2016, 01:52 PM   #690
Finalist's Avatar
I'd love to see that servo opened up to see what's inside of his version. Could be the same retail thing, but I would not be surprised at all if it used higher quality stuff -- a very typical move in all sports and hobbies.
Finalist is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
