Team Associated B6 & B6D thread
#6781
anyone know why MIP is discontinuing there puck and bi-metal ball diffs?
Are they coming out with something new?
#6783
Starting a new B6 build and wanted to get some opinions on a stock 17.5 setup.
Here's what I have in my shopping cart so far.
Team Kit RC10 B6
Avid Triad Stock Slipper Clutch (72t)
Avid 7mm Clamping Wheel Hex Set
Maclan MMax Pro 160a ESC & Maclan 17.5 SS Motor Combo
Robinson Racing 48p 30t Pinion Gear
Futaba S3305 Standard High-Torque MG Servo
Reedy Zappers LiPo 3600mAh 100C 7.6V LP Shorty
Any other must have upgrades?
Team Kit RC10 B6
#6784
Only must have upgrades imo is the aluminum d block and brass c block (12 or 25g)I'd get a pinion closer to 30t, and maybe swap it out for a parma plastic one or 175RC PolyPro. If you're running on clay/dirt get a ball diff. Kit should already come with 7mm rear hexes. Grab some 5mm or 6mm if you want to buy spares. Stock slipper is fine, but you could always buy a lockout (exotek/schelle/avid etc.) to have that option.
#6785
Broke my b6 stock wing on the first race. I wanted to try jconcepts aero s-type wing out so i bought a couple of this. Im running a bumpy high grip carpet track, what wing do you use?
#6786
#6787
#6788
#6789
Team Kit RC10 B6
Robinson Racing 48p 20t Pinion Gear
Team Kit RC10 B6
MIP pucks is also a nice upgrade
#6790
Will the old AE Axle hub w/ the TLR bones work with the new hubs, or do we need the complete axle/hub combo?
#6794
Gear depends on lots of factors but we are running 6:1 on 17.5t currently.
I would suggest something close to 6.5-7:1 as start.
