Team Associated B6 & B6D thread
#6646
https://www.amainhobbies.com/losi-ba...331006/p536647
same offsets, throw as AE one made in 23T and 25T
#6647
Sunday I got another 3rd place podium finish with the B6D latemodel.
The fastest guys in Sprint Car are running AFX converted B6's
If I was going to run a Sprint id just get the Custom Works.
Just to let you offroad guys know a B6 and B6D can be competitive in dirt oval also.
#6648
is that where you are hitting?
#6649
I got my long tower and b5m rear shock kits today. I sprayed one side of the shock tower with the clear flex seal as suggested earlier in this thread. It looks like crap and dries foggy not clear. Don't think I like that much.
As someone said earlier; I can just move shocks from my b5m over. So, I just built the shock kit with the eyelets that came with them which look the same as the short eyelets from the b6d kit. As such, I had +5 spring perches on the b5m so I put + 5 on these for the b6d as well.
I put the same pistons and springs that I had on the stock b6d shocks and used the same mounting locations. My goal was to not to negatively change the setup and handling from what I already had...as I liked it the way it was for now. Just looking to improve the cushioning from the added oil volume and if I get a little extra rear grip...well, I won't complain about that either.
Does it sound like I am going about this right? Or, am I missing/forgetting something?
#6650
Mounting Tires - Holes or No Holes
I am mounting a set of Gold Dirt Webs on Associated Rims for my B6 that I use on a Clay track. The rims have holes already....do I put holes in the tires also?
#6651
If you race outdoors on looser dirt, it's better to vent the tires and plug the rims so dirt can escape.
#6652
Anyone else having trouble with the pin (trans side) coming out of the 67mm Schelle aluminum bone? Have about 10 packs on mine and if I don't hammer it back in every run it'll work its way out. Emailed Schelle, zero response. They are basically trash at this point, pretty lame.
#6653
#6654
#6655
(The newest batch of CVA bones have a custom machined drive pin which will not shift in the softer aluminum material.)
New Schelle B6 67mm Lite hybrid CVA conversion set :: LiveRC.com - R/C Car News, Pictures, Videos, and More
#6656
#6657
Finished up my 3rd race day (back in the hobby after a few years off). Decided to run mod buggy since turn out was light for the holiday weekend. Even though I have ran 1/8th scale ebuggy, It is the first time I have run mod buggy since the early 90's. Ran my new B6 with Tekin 8.5. It killed my driving. I have ran my stock buggy the last two race days and they went really well. After the first two heats today, I decided I was ruining my driving style. The two days running stock buggy I felt like I was getting the hang of it back in short order. Dropping the mod buggy on the track I honestly felt like a true beginner. It was like a light switch for power. Either on or off and no in between. The driver was horrible! Anyway, after round two they had some down time and I asked if I could make a few laps with my stock buggy. After a couple of laps of getting used to "no speed"...I turned faster laps than I had been in mod. So the moral of my story is....no mod buggy for me for a while. Start slow....get smoother...then try to go faster!!
#6658
R/C Tech Elite Member
Portx that's 100% the truth man. I run a 7.5 on a larger track with the punch turned wayyyyyy down for the tight stuff so I can still be smooth but have the top end I want on the long straights. At a smaller track I run at I use a 17.5 in the mod buggy class and I've NEVER been out motored or failed to be on the podium due to the little motor. A smaller track is all about corner speed and smooth throttle over power and I've won mod buggy with a 17.5 there. Huge tracks are a different story though of course.
#6659
Slodsm...yes this is a smaller indoor carpet off-road track. I made the mistake of buying a stock buggy, mod buggy and a 4wd B64 all at once basically. I really should have taken my time and started at stock buggy for an extended time. After the first night in stock buggy I thought to myself..."oh yeah I remember how to do this and it will come back quick". Well mod buggy just gave me a reality check! The mod buggy and 4wd car will have to wait. Sadly the 4wd car has not hit the track yet....
#6660
i found the opposite. when my ESC started playing up and i lost a bit of punch i found i was having to overdrive the car to keep up with the pack. now ive got my grunt back i can relax a bit and not drive 11/10ths through the turns and jumps but still make good lap times
