Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 05-20-2016, 09:17 AM
  #586
Finalist's Avatar
Originally Posted by dsms4ever
Amain gives the date of June 17th?? Come on tower!
maybe Tower has sold out of their June pre orders and the July date is the second run delivery date?
Finalist is offline
Old 05-20-2016, 11:05 AM
  #587
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
if you had to pick one version of the vehicle and add something simple to it (say either laydown transmission or stand up transmission dependent on surface), what version of the car would you get to use on both carpet and old school dirt conditions?
I am thinking the B6D and the laydown tranny maybe?
Cain is offline
Old 05-20-2016, 11:24 AM
  #588
JsK
R/C Tech Elite Member
JsK's Avatar
Way to many compromises,I would just pick up one of the loaded stupid cheap
B5ms as a dirt car and get a B6 for carpet.
JsK is offline
Old 05-20-2016, 11:35 AM
  #589
Kegman21's Avatar
Good answer. I am in a similar situation. I decided on the B6 due to the fact that I would run a laydown transmission anyway. It looks as though Spencer Rivkin is running his B6 versus the B6D. He has done a few things like shock tower changes and the front arm changes, but he is primarily stuck with the car that he first got which was the B6. As he is the world champion his setup works for me.
Kegman21 is offline
Old 05-20-2016, 12:09 PM
  #590
Finalist's Avatar
Yes, but what diff is Spencer running?
For medium to high traction dirt clay it seems cheaper to go with the D and buy the lay down parts rather than buy the b6 and then buy the D parts.
It seems like the most popular car will be the b6D with lay down, ball diff and flat front arms.
Finalist is offline
Old 05-20-2016, 02:02 PM
  #591
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
ok...if you only want one car....It does not matter. you are going to want a gear diff for carpet, and that wont be awesome on dirt. Figure out where you plan to spend most of your time. and buy that car. I would personally get the 4 gear stand up for dirt outdoor. since neither car comes with that, then the diff will be a big decider. you will need a gear diff for carpet....and a gear diff can be made to work ok outdoors. might need a fluid change. Based on that....I would say get the carpet car if you plan to spend more than 60% of your time on carpet. and buy the 4 gear diff box. maybe even build a complete gear box for and easy swap. all depends on the prep time between tracks.
Wildcat1971 is offline
Old 05-20-2016, 02:05 PM
  #592
spencer basically had something closer to a b6d. flat arms, flat tower and ball diff.
Ok, brent said this in the best possible way, and this should be on the first page.
There are 3 main differences in the 2 cars.
-Gear Diff / Ball diff.
-Front flat/gulwing arms and tower
-Laydown/3 gear stand up.
Pic 2 of the 3 that you want and buy the kit that comes with those. Very simple.
Old 05-20-2016, 06:07 PM
  #593
RCBuddha's Avatar
Trader Rating: 40 (100%+)
anyone good at flow charts? Someone should make a ridiculously complicated one that we can point new folks to.
RCBuddha is offline
Old 05-20-2016, 06:10 PM
  #594
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
How about this....Posted to B6Nation by Kody Numedahl:
There seems to be some confusion about which car to buy between the B6 and B6D. A lay down gear box isn't the only difference between the two kits. The B6 also comes with a gear diff and gull-wing arms/tower. I attached a photo showing some common configurations that drivers will want to run and which kit I would recommend for each.
Matt Trimmings is offline
Old 05-20-2016, 06:53 PM
  #595
RCBuddha's Avatar
I'll figure something out...I was thinking of something like this;
RCBuddha is offline
Old 05-20-2016, 07:17 PM
  #596
Kegman21's Avatar
Kegman21 is offline
Old 05-21-2016, 09:56 AM
  #597
Originally Posted by 190mph
. Also if there is an excel based link to download?
Attached; i just C+P'ed into excel. had to zip it though b/c of restriction on valid attachment formats.
File Type: zip
shdwboxn is offline
Old 05-21-2016, 10:32 AM
  #598
Crazy. I per-ordered two days after they became available and mine shows mid-july as well.
Bomba is offline
Old 05-21-2016, 11:40 AM
  #599
They probably got an updated delivery date and knowing Associated will not deliver these in June and will miss like everything else.
But when Tower gets the shipment in of these 2 kits they will never go out of stock for like a half a year. They get so many.
190mph is offline
Old 05-21-2016, 12:11 PM
  #600
aeRayls's Avatar
As to which kit to buy, the way Brent explained it (which wildcat shared) is pretty spot on. To me it's this simple:
The only reason to buy the B6 is if you plan to run carpet or turf, that's it!
For any other surface including switching back and forth between dirt/turf/carpet etc buy the B6D and any parts to convert as it'll be cheaper and easier.
aeRayls is offline
