Team Associated B6 & B6D thread
#5821
Trader Rating: 89 (100%+)
More steering
i installed the +1 plates and will need to install the gullwings which i have purchased. I have made some changes to the car so I will make additional changes to see how it works out but just driving it around the house it seems like it inherently has a wider turning radius... kinda strange.. but i am a strange guy so...
#5822
Had mine on the track for the second time, and really digging the car. Back end is a touch squirrel coming out of the corners on-throttle. I have the kit setup + laydown (shocks still on rear, though). Thinking of the following changes, in order:
- + 0.5 degrees antiquat
- Rear hubs forward
- Front lower shock mounts to B (middle) position
- 32.5wt front shocks
- Rear upper shock mounts to 1
- Rear hubs forward
Where are your shocks mounted front or rear of the tower ? I had to move then to the front of the rear tower. I tried moving the top rear shock setting in from center but it did not help. Also I added a 25g c mount and had to widen the rear of the car and went up +5 and out +5 on the c block. D block I went out +5 from stock and I may now move the rear mounts down a half . I found on my track the car was very unstable out of the corner with the box stock set up.
Another thought is to check the rear diff and make sure it didn't loosen up as it wore in
#5823
Jason , I went to laydown on the B6d and had to make a bunch of changes in the rear . I run on highbite clay/dirt mix with m4 primes
#5824
Move The Shocks !!!!
I left the shocks on the rear of the tower, just to help keep some weight back there. I still have the stock C/D blocks on the rear... might pick up the alum C block. I'm still wrapping my head around the hold positions and what they do so forgive me, but wouldn't going out +5 on the C block decrease toe-in?
#5826
http://site.petitrc.com/setup/associ.../B6_PillChart/
http://site.petitrc.com/setup/associ...upb6/B6_Chart/
#5828
Not sure how that solves the rear traction issue coming out of the corner, though... front of tower = less rear weight bias / less rear traction.
#5830
#5831
#5832
Lol
#5833
#5834
#5835
Night and day difference....
