    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree323Likes
Old 05-19-2016, 08:56 AM   #556
Originally Posted by Wildcat1971 View Post
you are correct. According to AE. to lover the CG.
Thank You, I am just trying to get all the parts here so that I can have that stuff ready to go when my B6 and B6D come in. So are the B6 and the B6D both going to have the 27mm rear shocks then I am assuming?
Jade67 is offline   Reply With Quote
Old 05-19-2016, 08:58 AM   #557
As far as hobbies go, rc is pretty cheap.
I totally agree. I could build another Drag quad and really piss my wife off...lol
Old 05-19-2016, 08:59 AM   #558
Super Moderator
Originally Posted by Jade67 View Post
So looking at the parts list that is interchangeable between the B5M B6 and B6D I have one question about the FT Kashima/Fox Shocks. It has the ASC91576 (23mm Front) being used on all three but my questions comes with the ASC91577 ( 27mm Truck) is said to be used with only the B6/B6D and the ASC 91578 (31mm Rear Buggy) are used with withe only the B5/B5M.
Why is this? Did they really make the rear shocks 5mm shorter for the B6 series vehicles or am I missing something here?
I suspect partly because of generally smoother surfaces and somewhat stiffer setups expected, less travel needed, seems to make sense.
Dave H is offline   Reply With Quote
Old 05-19-2016, 09:29 AM   #559
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Correct. Both cars have the 27mm rear shocks.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-19-2016, 09:38 AM   #560
Suspended
Trader Rating: 61 (100%+)
Saw this with both the Xray and the YZ2 - a noticeable lack of droop for both cars, dirt and carpet.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 05-19-2016, 10:10 AM   #561
Super Moderator
Yes, pretty basic setup stuff. Rough lower speed tracks need more travel, especially droop, more linear/vertical shock positions, less spring and especially damping. Smoother the opposite. Things the bench test methods, while useful to a degree, frequently don't incorporate very well.
At the extreme due to the variety of tracks we have or had in the areas I've primarily club raced at we would change shock lengths and towers track to track even.
Old 05-19-2016, 10:39 AM   #562
Trader Rating: 14 (100%+)
Default new buggy
Ok, people complain about AE for making a New buggy. But here are people that want a new platform. Make up your minds. They had issues with B5M, so they worked on making it better. It will be the same story. If AE left b5m alone people will complain that they don't care about us . They are not just for money, they want to win, just like any other company. Look at Losi, they just made 3.0, to catch up with the times. I see a Losi 4.0 coming, because 3.0 has many flaws, just like b5m. So people that say AE just wants money, than go buy another rc , and give them your money. This is how all companies stay in business, not just AE. I'm glad they made changes, these changes are what people wanted, remember that.
RodRC is offline   Reply With Quote
Old 05-19-2016, 11:38 AM   #563
B5m has many flaws? Most of them were addressed in the factory lite version which I happen to have. Other than ALL cars having flaws the B5m was a successful overall platform for 90% of people.
Pros are gonna tinker with cars no matter what it is
Slashn77 is offline   Reply With Quote
Old 05-19-2016, 11:39 AM   #564
aeRayls's Avatar
there's actually no less down travel with the shorter shock bodies. The same shaft is used and the shock tower is lower than the b5m. Unless of course the shock tower wasn't lowered the same amount as the shock bodies, but I do believe I read that Kody said it was.
aeRayls is offline   Reply With Quote
Old 05-19-2016, 11:54 AM   #565
Jmuck69's Avatar
If you remove the shock cap of the current B5M rear shocks, there is a good 4mm + of space between the piston and cap. So going to a 27.5mm rear bodies will not reduce travel, just eliminates the dead space thus reducing height.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-19-2016, 12:08 PM   #566
Super Moderator
Ah, good info, thanks.
Old 05-19-2016, 12:25 PM   #567
Thanks for the insight with the rear shocks. I am going to have to order a few sets for when my B6 series whips come in
Old 05-19-2016, 02:12 PM   #568
Default flex,
Factory light chassis needed more flex, shock position in the rear is a great option to provide more traction, able to adjust hieght of car through caster and hubs. So many changes, b5m is a great car but some stuff needed change. I'm just saying the guy saying associated is just in it for the money is wrong. They just wanted to be even more competitive. So it's going to cost us and them to get us a car we can adjust to many track conditions. B5m is still a great car. People would have complained about AE that they keeping an outdated car, but now that they improved on things that b5m didn't have. Some are complaining it's for the money. Well could be some what true but it's for the cost of providing a little better platform. Every company does it. So who ever don't like just give money to another company, no matter what your going to spend money in this hobby, no matter what brand.
Old 05-19-2016, 04:39 PM   #569
JayL's Avatar
SC6?
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 05-19-2016, 04:45 PM   #570
Super Moderator
Originally Posted by JayL View Post
SC6?
Kyosho makes one. Check out that thread.
Currently Active Users Viewing This Thread: 10 (3 members and 7 guests)
Dragon01826, jmcelroy42, Scott R
