    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 01-31-2017, 04:44 PM   #5491
71schaeffer's Avatar
Trader Rating: 8 (90%+)
Originally Posted by Lunchie View Post
have a look at the manual and see if the combination of toe/antisquat is what you need. if it is then theres no point in getting the d block. the d block just allows settings outside of whats available on the stock d block.
Yea I was just wanting to know if I take .5 out of stock setup for a highbite track if that will free the car up a tick and rotate more through the tight 180's. if so then should I do the same thing to the d block. I am still trying to understand when to add and subtract antisquat so idk when I would use that setting lol
Hobbytown USA Gladstone,MO / StickyKicks RC / Fantom Racing / Clints Creations
71schaeffer is offline   Reply With Quote
Old 01-31-2017, 05:30 PM   #5492
no you leave it where it is so the relative position is different. so for you to remove some toe from stock youd change the c pill from .5 out to 1 out to give 2/1 toe/antisquat. if you THEN wanted to add .5 antisquat youd need a d block as the 2/1.5 isntan option with just the c block.... you coul dhowever run 2.5/1.5 with just the c block...confused? lol
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Old 01-31-2017, 05:39 PM   #5493
I'll just focus on bettering my driving
Old 01-31-2017, 06:40 PM   #5494
Those pills will melt your brain if you're not quite sure what does what. There are about a million combinations you could do there. I don't have this car... but to free it up, I would raise the roll center. So, say .5 up on the C mount and .5 up on the D mount. To see what more antisquat does, try 1 up on the C mount (with .5 up on the D mount still).
will5879 is offline   Reply With Quote
Old 02-01-2017, 12:48 AM   #5495
just try raising you roll center by only using 2mm shims under the inner ballstud instead of 3mm. then maybe go for less toe in the rear by going out by .5 on the c block. dont get too hung up on the d block just yet...drive it and see if you like it. the box setup is pretty damn good right out of the box if just a little bit low on roll center on the rear for my liking.
my car running a box stock setup on carpet was within 0.2 seconds a lap from the Amain winner in a tricked out YZ2 so the setup is good. (not like my driving however)
RC10 B6
LC Racing truggy,
Old 02-01-2017, 04:25 AM   #5496
I think ill start there and slowely work my brain in some different areas. I love the car, ill post a pick of it today! Ive been working on it almost 3 times a week racing and practicing and I've noticed last month my quickest time was around a 15.6 now im down to a 15.1! Thanks for the help on information, the questions can be ongoing sometimes and I apologize
Old 02-01-2017, 06:13 AM   #5497
Originally Posted by Silverstonev8 View Post
Mine are approximately 75mm front and 88mm rear
If I remember correctly I have 2mm spacers in the fronts. I started the build a while back but got sidetracked by a 1/5 scale project. I just finished it a couple days ago...
Thanks a lot
Rogntudju is offline   Reply With Quote
Old 02-01-2017, 06:28 AM   #5498
I would say if you want the car to steer more around a tight 180 then you would want to add rear toe, so if you where at say 2 or 2.5 degree toe then you would want to go up to 3 degrees
roysays is offline   Reply With Quote
Old 02-01-2017, 08:53 AM   #5499
rgrg2's Avatar
Trader Rating: 42 (100%+)
Default C mount
Are most people using the 12g or 25g Brass C Mount in the B6 and B6D for stock racing? Is it a necessity?
Associated B6D B6 MT4S Jconcepts Reedy Schurr Speed Hobbywing Tekin
rgrg2 is offline   Reply With Quote
Old 02-01-2017, 01:47 PM   #5500
ray_munday's Avatar
So I was wanting to get the aluminum D mount, just thought I would ask because I personally haven't asked this before but if you change toe or anti-squat on one block do you have to replicate it on the other one as well?
The D block allows additional adjustments as you can raise / lower the hinge pin (which has a big effect on roll centre) and you can make the spacing of the pins wider or narrower (which has a big effect on rear stability on and off power). You can then adjust squat and toe by adjusting the c/d blocks relative to each other.
On lower traction dirt we run the pin spacing narrower for more rear grip on exit. On carpet they tend to run the spacing wide. Im told on indoor clay they run them higher to get more steering.
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 02-01-2017, 02:18 PM   #5501
Thanks that answered a lot of my questions
Old 02-01-2017, 04:29 PM   #5502
Ruffdog1's Avatar
I don't see how the 31mm rear shocks help if you use the same 27.5mm shaft. Can someone please explain? Thanks!!!
Ruffdog1 is offline   Reply With Quote
Old 02-01-2017, 04:49 PM   #5503
Trader Rating: 91 (100%+)
more oil
redracerd is offline   Reply With Quote
Old 02-01-2017, 06:14 PM   #5504
Ruffdog1's Avatar
Originally Posted by redracerd View Post
more oil
Yes more oil but how does that help? the stroke is the same.
Old 02-01-2017, 06:28 PM   #5505
Trader Rating: 18 (100%+)
Think about the advantages when we went to big bores shocks. More volume for the piston to move through. The on track difference has been a better jumping and more plush buggy.
Chris Brown is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (3 members and 2 guests)
Kelseyrc, windellmc, yodace
