    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree371Likes
Old 01-19-2017, 09:14 AM   #5326
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Logi Maker View Post
That is a POS. I use this for making receiver connectors and balance lead for charger lead.
I like this one, because I can do a bunch of different crimps an I dont have to adjust the tool.
https://www.amazon.com/Engineer-PA-0.../dp/B002AVVO7K
If you ONLY want to do "1" thing, you can get a ratcheting crimper. but get a bunch of connectors to practice on and to adjust the crimps for crush force.
http://www.hansenhobbies.com/product...ools/crimp_dx/
I also get the pins and housings from hanson. His JR housings fit Sanwa receivers better any connector besides the Z connectors from sanwa.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-19-2017, 09:19 AM   #5327
No lie, I use needle nose pliers to crimp my servo leads. It's not the easiest way, but it works if you don't have the crimper. I'll be investing in a crimper soon though.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 01-19-2017, 09:29 AM   #5328
The one thing I hate if you do that then you cant use the speed control or Servo in another vechicle it will be set for that specific vechicle.
That's why I don't wanna cut those wires to make them shorter. Just in case I wanna use those those electronics in another R/C.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 01-19-2017, 09:31 AM   #5329
Mason's Avatar
just watched the video on the page. suddenly i want to rewire my car. then i realized I have more important things to do this week.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-19-2017, 09:33 AM   #5330
Mason's Avatar
bmag, I have the same mindset so I just fold up the wire, slip on some heat shrink and then snug it up a bit. shoe-goo the wad to something so they don't move.
Mason McCombs
Old 01-19-2017, 10:52 AM   #5331
Logi Maker's Avatar
Trader Rating: 49 (100%+)
I actually use this one... cheap, works great...
https://hobbyking.com/en_us/hobbykin...ping-tool.html
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 01-19-2017, 11:29 AM   #5332
Trader Rating: 25 (100%+)
I open my ESCs and re-solder a custom length lead internally. Very clean and not hard if you're careful.
jonnymorrow is offline   Reply With Quote
Old 01-19-2017, 11:41 AM   #5333
I do this as well. some esc/servos are harder to do this on. I dont mess with internal soldering until it is out of warranty.
Old 01-19-2017, 11:42 AM   #5334
My buddy has this. I tried it. It is ok....I just dont like yellow
Old 01-19-2017, 02:45 PM   #5335
This from a guy that dries a pink car
jslider is offline   Reply With Quote
Old 01-19-2017, 06:11 PM   #5336
Azzkikin's Avatar
Hey guys figured I'd share my final weight savings for the tranny.
This is the stock B6D running gear (ball diff)
This is the lightweight setup. MIP B5/B6 "Super Diff" Bi-Metal Differential Kit (w/o the std kit balls), 175RC pinion, MIP ASSOCIATED 17.5 B6 B6 SERIES Race Topshaft, RCSS Associated B6D Cut Diff Gears, Protek Spur and Lockout.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 01-19-2017, 07:00 PM   #5337
Trader Rating: 488 (100%+)
Stupid question that's probably answered a couple hundred pages back....if I use the AE FT aluminum hubs, do I really have to but them on backwards? If so, any insight as to why? I haven't tried them yet on the B6.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 01-19-2017, 09:42 PM   #5338
Trader Rating: 16 (100%+)
Originally Posted by Sodakota View Post
Anybody known a stubby shortie wourks in this car?
B6D can use square or shorty packs. B6 is shorty only. Not sure what you are referring to as a stubby shorty.
MX304 is offline   Reply With Quote
Old 01-19-2017, 11:58 PM   #5339
Pinkz's Avatar
stubby shorty or super shorty is a 2S pack that is near same size as one of the 1S packs of a 2S saddle pack
http://www3.towerhobbies.com/cgi-bin...&I=LXGBXH&P=SM LRP LiPo 7.4V 2600 Spr Shrty
http://www.ebay.com/itm/like/2319698...&ul_noapp=true ARROWMAX Lipo 2800mAh 2S Super Shorty
https://hobbyking.com/en_us/turnigy-...-approved.html Turnigy nano-tech Ultimate 2600mah 2S2P 90C Hardcase Lipo Super Shorty Pack
some racers at my track make their 8 minute 17.5 mains with their 1/10th buggies with no issues on runtime
It rubs the lotion on its skin or else it gets the hose again.....Yes, it will, Precious, won't it? It will get the hose! https://www.youtube.com/watch?v=cyn0DVSn96I
Pinkz is offline   Reply With Quote
Old 01-20-2017, 01:24 AM   #5340
aeRayls's Avatar
If your shocks are on the front put the 0 facing forward. Shocks on rear 0 facing the rear.
aeRayls is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Larryscooterman
