    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 01-18-2017, 02:50 PM   #5311
SnotRkt's Avatar
Got my Spektrum S6240RX rx/servo combo installed. Seems nice.
AE RC10B6, TD DEST210R
SnotRkt is offline   Reply With Quote
Old 01-18-2017, 02:55 PM   #5312
denon's Avatar
That looks so clean. Great Job! What kind of covering are you using on the esc wires.
B6 | SC5M
denon is offline   Reply With Quote
Old 01-18-2017, 03:00 PM   #5313
SnotRkt's Avatar
Thanks! I try to make my setups as clean as possible. I think I'm going to cut the esc wire and put a new end on it. Anyway, its expandable wire loom with shrink wrap at the ends. It's called Techflex and I bout a few different sizes through Amazon for different projects.
Old 01-18-2017, 03:34 PM   #5314
What do you call that mesh stuff that you cover your ESC wires with? I want to get some of that stuff to make some charger leads but don't know what it's called to google it to purchase
mgers75 is offline   Reply With Quote
Old 01-18-2017, 03:53 PM   #5315
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Www.wirecare.com
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 01-18-2017, 04:04 PM   #5316
SnotRkt's Avatar
Techflex is what I purchase on Amazon
Old 01-19-2017, 05:37 AM   #5317
Looks like the new hubs are pretty close to final product.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 01-19-2017, 07:13 AM   #5318
Default Everyone posting thier electronics install I'll post mine. :)
bmag5000 is offline   Reply With Quote
Old 01-19-2017, 07:25 AM   #5319
Stick pack is fine for oval but I wouldn't run it offroad that way.
I run the gear cover 2 of my tracks are loose dirt so that will keep the dirt outa my gears.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
Old 01-19-2017, 07:36 AM   #5320
Davidka's Avatar
Trader Rating: 75 (100%+)
Originally Posted by bmag5000 View Post
That's more like how my stuff tends to look.
I'm more interested in the body mounts. Do you run oval with that car?
Old 01-19-2017, 07:40 AM   #5321
Logi Maker's Avatar
Does all that extra wire help it turn left better?
Kyle Predmore
Old 01-19-2017, 07:46 AM   #5322
SC10 Body mounts the old SC10, not the Sc5m.
Yes I run oval with this car. It drives much better than I thought.
Old 01-19-2017, 07:47 AM   #5323
Not really but zip ties tend to keep it tiedy a little bit better.
Old 01-19-2017, 07:54 AM   #5324
Logi Maker's Avatar
https://www.amainhobbies.com/protek-...k-1999/p503208
Kyle Predmore
Old 01-19-2017, 08:07 AM   #5325
Trader Rating: 50 (100%+)
That thing is crap. If you want one I recommend amazon.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
Cappy, Kpb102772
