    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree368Likes
Old 01-18-2017, 04:34 AM   #5296
DayDAY's Avatar
Default What is the diff between mounting the rear suspensions in front and rear of the tower
Hi guys, I just got a new B6 and it was awesome. I'm now trying to do different setup to make better performance. Can anyone tell me what is the difference between mounting the rear suspensions in front and at the rear of the tower, thank you
DayDAY is offline   Reply With Quote
Old 01-18-2017, 06:28 AM   #5297
Trader Rating: 25 (100%+)
Originally Posted by jonnymorrow View Post
Thanks for this Chris Brown. Will give it all try.
Big change, that I could actually feel, was changing roll center by using the .5-1 up pills in both c and d-blocks. Also, if on high bite clay, changing the axle height can help if you have so much grip to traction roll and are running lower (~20-22mm) ride height.
joncmack is offline   Reply With Quote
Old 01-18-2017, 07:57 AM   #5298
What difference does it make using the long or short spring cups?
Does it make the car handle better if you use the short cup and have the spring collar lower on the shock body threads as opposed to using a longer cup and having the collar higher on the threads?
I'm asking cause when I switched to the Yatabe springs they were shorter so I just switched to the taller cups instead of screwing the collars down.
roysays is offline   Reply With Quote
Old 01-18-2017, 08:51 AM   #5299
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
zero performance effect. It's just to achieve proper ride height on various surfaces/spring lengths.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-18-2017, 10:20 AM   #5300
Dougefresh35's Avatar
Trader Rating: 18 (100%+)
Anyone know what does lengthing and shortening the top turnbuckle above the suspension arms do more grip less grip I can't remember. Thanks
Dougefresh35 is offline   Reply With Quote
Old 01-18-2017, 10:30 AM   #5301
RC-ZOMBIE's Avatar
Hi guys on page 15 in the manual it contradicts itself between long and short shock eyelets which one goes where? Never mind
RC-ZOMBIE is offline   Reply With Quote
Old 01-18-2017, 12:56 PM   #5302
mr240's Avatar
Trader Rating: 61 (100%+)
What did you find out. Building my B6D and not sure what shock eyelets to use for the kit setup.
mr240 is offline   Reply With Quote
Old 01-18-2017, 01:01 PM   #5303
The stock setup sheet in the back of the manual says use long eyelets front and rear
Old 01-18-2017, 01:14 PM   #5304
Read the wiki at the top. All your questions have been asked before. And answered.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 01-18-2017, 01:40 PM   #5305
jabroni racing's Avatar
Trader Rating: 37 (100%+)
Send a message via Yahoo to jabroni racing
My manaul told me which ones, In the left side of the pic I beleive
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 01-18-2017, 01:42 PM   #5306
here is the picture
Old 01-18-2017, 02:35 PM   #5307
Mason's Avatar
It was in the wiki, the answer has been removed or never completely entered.
I believe the correct answer:
front of rear arms - short.
rear of rear arms - long.
This is allegedly fixed in the on-line manual. So it wouldn't hurt everyone to download it to their phone for track-side needs.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-18-2017, 02:40 PM   #5308
It was in my manual.. Maybe earlier runs were missing it..
Old 01-18-2017, 02:51 PM   #5309
tsair's Avatar
Wow, I just got a new B6D from Tower 2 days ago, and I'm 95% sure the eyelet explanation was contradictory in the manual -- I was building my shocks about an hour ago. The pic from jabroni racing shows consistent and accurate information though!
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 01-18-2017, 03:26 PM   #5310
ollie 45's Avatar
Can saddle packs be used in the B6 with a laydown transmission?
ollie 45 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 10 (2 members and 8 guests)
cbazq271, windellmc
