    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree323Likes
Old 01-17-2017, 03:50 PM   #5281
jabroni racing's Avatar
Trader Rating: 37 (100%+)
Send a message via Yahoo to jabroni racing
These are the hub inserts
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 01-17-2017, 04:18 PM   #5282
Trader Rating: 25 (100%+)
Yeah totally vague I know. But tough to describe. I think I'm looking for more response all around. More rear bite, more steering. Just easier to drive. I know that's a ridiculous comment.
I guess let me know if there are any adjustments/tricks that everyone is for sure doing.
jonnymorrow is offline   Reply With Quote
Old 01-17-2017, 04:40 PM   #5283
Trader Rating: 22 (100%+)
what track
Coke in a can is offline   Reply With Quote
Old 01-17-2017, 04:41 PM   #5284
Oh yeah, my bad. SCVRC. Med/High and tight.
Old 01-17-2017, 06:30 PM   #5285
JsK
JsK's Avatar
Hey guys. Took my new B6 out for its first practice day yesterday. Cool kit but it actually didn't blow my mind like I thought it would. Feel and drivability was similar to my old B5 and in some ways the B5 was better. I'm sure there are many factors involved here but my question is, are there any MUST DO adjustments for the B6? With the B5 there were things like 3mm trailing inserts, pistons and hub adjustments that just made the car way better. Anything like that on this platform? I'm on medium/high bite clay running lay down, gull wing and ball diff. Car is good but not amazing. Thoughts?
I would have recommended a B6D with a laydown instead of the B6 you describe. There are quite a few differences that are going to take away to
much grip on clay.
Have you been to Petitrc yet?
http://site.petitrc.com/setup/associ...tedRC10B6.html
JsK is online now   Reply With Quote
Old 01-17-2017, 06:46 PM   #5286
I am running a B6D with laydown. See my post. Are you saying go to flat arms?
Old 01-17-2017, 06:49 PM   #5287
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Try Kurt's flat arm OCRC setup from the B6 nation on FB....
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 01-17-2017, 06:51 PM   #5288
Logi Maker's Avatar
Kyle Predmore
Old 01-17-2017, 06:52 PM   #5289
JsK
JsK's Avatar
I saw your post and I didnt see a D anywhere.
Doesn't matter though. PetitRc is a great source for setup sheets. There are
several for SVRC.
Old 01-17-2017, 06:55 PM   #5290
Will try that setup. Thanks Logi Maker.
Anyone else with changes that made a big improvement?
Old 01-17-2017, 07:56 PM   #5291
jonski's Avatar
Trader Rating: 239 (99%+)
Originally Posted by jabroni racing View Post
What hub inserts are you looking for?? I bought the carbon fiber ones & battery strap from here
https://www.facebook.com/Breathless-...3956091868322/
I am looking for the bearing inserts that space the hexes out a bit so I can run the 67mm driveshafts.
jonski is offline   Reply With Quote
Old 01-17-2017, 08:17 PM   #5292
Trader Rating: 18 (100%+)
Spacing the front bulkhead 1mm livened up the steering quite a bit. The flat arms are more responsive than gull wing. The middle lower shock hole also made the steering more aggressive. Also try the schelle +1 front steering plates. For the rear, try running .5 up in the pills o Venus 1 up. Shocks in front of to tower add steering as well.
Chris Brown is offline   Reply With Quote
Old 01-17-2017, 10:11 PM   #5293
JsK
JsK's Avatar
[email protected], He got back to me in a couple hours.
Old 01-18-2017, 01:05 AM   #5294
Thanks for this Chris Brown. Will give it all try.
Old 01-18-2017, 03:28 AM   #5295
http://site.petitrc.com/setup/associated/setupb6/B6D_KurtWenger_OCRC20160921/
I used this set up but only change things I could with the stock kit. I also run 35 front and 30 rear for oil. My shocks are also stock setup in terms of length and springs
I do have a lay down. I love the way this drives. Great starting point setup. I even took it of a loamy track and it handled surprisingly well using duratrax equalizer rear and ribs front.
caioz1jp is offline   Reply With Quote
Currently Active Users Viewing This Thread: 10 (2 members and 8 guests)
Dragon01826, jmcelroy42
