    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 01-16-2017, 09:42 AM   #5236
For anyone running losi 22 3.0 rear hubs/axle and dogbones, what camber link setting and ball stud spacing?
killshot01 is offline   Reply With Quote
Old 01-16-2017, 09:53 AM   #5237
Jmuck69's Avatar
Trader Rating: 14 (100%+)
I don't think the hubs are part of the equation. People are running the BMI spacers with the 67mm Losi dogbones
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-16-2017, 10:41 AM   #5238
Phillip F's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Jmuck69 View Post
Either the stock body or JC S2. The stock body is really nice looking.
Jc is introducing the new Finnisher F2 bkdy for the B6 on the Reedy race. Its about time.
Phillip F is offline   Reply With Quote
Old 01-16-2017, 11:10 AM   #5239
Default Gearing
Hey all,
I'm running an ecopower slingshot 17.5 motor in my B6D with a 31 pinion and 69 spur. Everyone at the track looked at me like I had 8 heads. I showed them the manual recommends this gearing. Saturday was the first time I ran this buggy. Am I insane or are others just out there? I should note they were all running different motors too (modified).
I'll be running it again tonight to check motor temps.
bongoray is offline   Reply With Quote
Old 01-16-2017, 11:27 AM   #5240
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Gearing should be somewhere close to that.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 01-16-2017, 11:34 AM   #5241
Azzkikin's Avatar
With a 17.5 I am at 31-33/69 and with a 1S motor I am at 28-30/69. Each car is different for cooling also. I say you are pretty right on.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 01-16-2017, 11:41 AM   #5242
Trader Rating: 38 (100%+)
Gearing sounds close to me.
Lynne7399 is offline   Reply With Quote
Old 01-16-2017, 11:44 AM   #5243
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Originally Posted by AE_Stig View Post
2x1.8 flat lands better for carpet racing
cool thanks for the info. Do you feel it performs better than 1.7 when it gets bumpy at all?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 01-16-2017, 11:49 AM   #5244
Originally Posted by bongoray View Post
Hey all,
I'm running 33/69 on 17.5 because i needed more speed to clear a large table top on the existing layout. I've got no issues with it - I originally had a 72 installed but found the added top speed the 69 gave was allowing me to clear the larger gaps.
B64D | B6 | T5M | EB48.4 | Talion | EMB-TGH | Sakura Advance
daedalus is offline   Reply With Quote
Old 01-16-2017, 12:01 PM   #5245
Eli
Eli's Avatar
Originally Posted by sstretch View Post
Is everyone cutting their axles down when running the offset bearings, 67mm axle shaft and 5mm hubs? Or do I just run it with the extra threads sticking out?
Thank you
I leave the extra axle hanging out, occasionally I get a sweet spark off the straight away wall at my track.
Eli Westrup - SDRC Raceway
Eli is offline   Reply With Quote
Old 01-16-2017, 12:10 PM   #5246
Tech Legend
Cain's Avatar
Got the yatabe springs on order, so will see how it goes next session assuming it comes in on time. Amain was pleasant to deal with and matched towers member coupons.
Old 01-16-2017, 12:20 PM   #5247
I put green Yatabe on the rear and red on the front, running a B6 on astroturf.
Seems a tad better, hard to tell a big difference. I had the springs that came with the kit on it before.
roysays is offline   Reply With Quote
Old 01-16-2017, 12:46 PM   #5248
SnotRkt's Avatar
Just put the Yatabe reds on the front and the Yatabe greens on the rear. Man these springs are short! Are you guys going with longer spring cups or using the kit setup cups with these springs, the kit calls for 5mm offset cups in the front and 0mm cups in the rear. And just sitting the preload to touching the spring with no compression I get about a 15mm ride height. I did preload them to get me up to 17mm. I run on carpet with small to medium jumps, some flat landers and some have landing ramps...
AE RC10B6, TD DEST210R
SnotRkt is offline   Reply With Quote
Old 01-16-2017, 01:24 PM   #5249
Trader Rating: 24 (100%+)
if you run out of thread on the shock body, use taller spring cups to get your desired ride height
Associated B6 x2
Associated B64D
Associated B64
Associated T5M
Scott R is offline   Reply With Quote
Old 01-16-2017, 01:35 PM   #5250
SnotRkt's Avatar
Plenty of threads left. OK, thanks.
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
mitrich, Raulote, stueys, _AMA_
