    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree325Likes
Old 01-12-2017, 11:34 AM   #5191
Originally Posted by 2hundy View Post
What's the benefit in running 2 gears in the diff?
I switched to 2 gear with 15K because my o-rings were leaking with the stock 4K
Eddie_E is offline   Reply With Quote
Old 01-12-2017, 11:48 AM   #5192
Azzkikin's Avatar
Originally Posted by Sodakota View Post
Anybody known a stubby shortie wourks in this car?
If you mean like LRP has, I run them.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 01-12-2017, 12:11 PM   #5193
Trader Rating: 18 (100%+)
I don't know if you're looking for a lightweight battery but I just got the new protect lihv 3600 battery and love it. Without any weights and the 25 gram c block my car was 1452 grams. Added the brass weight plates and nondescript he electronics steel plate and needs the car handled best between 1541 and 1555 grams.
Chris Brown is offline   Reply With Quote
Old 01-12-2017, 12:17 PM   #5194
Did you keep both shafts in the diff?
2hundy is offline   Reply With Quote
Old 01-12-2017, 12:20 PM   #5195
no need
AE_Stig is offline   Reply With Quote
Old 01-12-2017, 02:21 PM   #5196
SnotRkt's Avatar
What an awesome idea! rx inside a servo! I'm pre-ordering one for my B6
https://www.amainhobbies.com/spektru...6240rx/p585268
AE RC10B6, TD DEST210R
SnotRkt is offline   Reply With Quote
Old 01-12-2017, 03:53 PM   #5197
Thrifty's Avatar
Is it possible to just pick up a gasket for the gear diff rather than buying a rebuild kit? Seems they sell them for some of the other vehicles...
Tekno 410.3 SL
RC10-B6D
RC10-B6
RC10-B64D
AuperD rwd drift.
Thrifty is offline   Reply With Quote
Old 01-12-2017, 04:11 PM   #5198
Jmuck69's Avatar
I think the diff gasket and seal kit for the SC10 4x4
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-12-2017, 04:15 PM   #5199
Azzkikin's Avatar
That's as close as you get, I think
Part #: 91462 https://www.amainhobbies.com/team-as...c91462/p275229
Old 01-12-2017, 05:06 PM   #5200
Silverstonev8's Avatar
Less useful parts but it's in this for $5
https://www.amainhobbies.com/team-as...sc9936/p366600
Silverstonev8 is offline   Reply With Quote
Old 01-12-2017, 05:18 PM   #5201
Trader Rating: 22 (100%+)
You want Associated part ASC9831
https://www.teamassociated.com/parts...ff_o-ring_set/
AMessy is offline   Reply With Quote
Old 01-12-2017, 05:24 PM   #5202
Thrifty's Avatar
Thanks guys... looks like the SC10 set fits.. sure make that hard to find...
Part #9831 for any of y'all that end up needing one,..
Edit-- Just saw your post AMessy... that's it.
Tekno 410.3 SL
RC10-B6D
RC10-B6
RC10-B64D
AuperD rwd drift.
Old 01-13-2017, 05:07 AM   #5203
What do u use for a battery strap? Did u custom build one or dors the kit piece work. I need some new batteries and am debating getting a stubby or just goong with a regular shorty. Thanks
Sodakota is offline   Reply With Quote
Old 01-13-2017, 06:43 AM   #5204
Azzkikin's Avatar
Go back to page 332 post 4973 Team Associated B6 & B6D thread
I have the part numbers I used for the battery strap. For this battery, the stock strap does not work. It covers the battery post and doesn't cradle it right. The HPI Hot Bodies does the job perfectly.
Old 01-13-2017, 06:48 AM   #5205
I only kept 1 shaft in with the 2 gears.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
