    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 01-07-2017, 09:57 AM   #5131
Phillip F's Avatar
Trader Rating: 17 (100%+)
Originally Posted by eper View Post
Ok guys I have a b6 lay down car that is dam dam good. The only thing I noticed was the when you put the rear shock on front of the tower u are moving the wing forward the thickness of the tower mount. I'm guessing about 6 mm has anyone tried running the wing way back in close to the position it would be in with shocks on the back of the tower? I think I. Gonna try it just to see. I'd emagine it would have more of a effect on high speed rear traction but that's probably it. And it might make it jump more nose high. If anyone's plated with this I'd like to hear your opinions. Thank you
how are you going to do this? I saw ine guy in shapeways who offers shock tower spacers 4mm and 5mm thick to do this.
Phillip F is offline   Reply With Quote
Old 01-07-2017, 10:20 AM   #5132
Originally Posted by Jon Carlson View Post
http://www3.towerhobbies.com/cgi-bin...&I=LXDVKZ&P=ML
This is the wheel you want, I chose the DE wheel because that's what you had. The Plus is the 60mm/2.4 wheel. This is the 2.2 wheel that works with the tires you had picked out. Good luck.
Thanks Jon and Thanks cain! Ill pick up the de or the monos
caffeine357 is offline   Reply With Quote
Old 01-07-2017, 12:28 PM   #5133
Sorry - this was posted to wrong thread... meant for 4wd.
PerryCodes is offline   Reply With Quote
Old 01-07-2017, 12:37 PM   #5134
Azzkikin's Avatar
Hey guys, figured I'd share some weight savings pics for the tranny. Although not much, it should help with rotational mass over powering the motor on braking and acceleration. And since I run a 1s motor, a little less to slow up would help.
This is the MIP top shaft, the RC Speed Secret cut gears and a smaller spur pinion combo.
Stock internals with 69 spur and 30 pinion
Cut gears and light top shaft with 66 spur and 29 pinion.
I haven't decided if I want to upgrade to the bi-metal MIP out drives yet. I had the pucks before and I was not a fan. Does anyone know if MIP has the out drives for bones?
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 01-07-2017, 01:08 PM   #5135
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
try it with this pinion: http://www.ebay.com/itm/Parma-29t-48...AAAOSw7aBVE-Ux
RC*PHREAK is offline   Reply With Quote
Old 01-07-2017, 02:41 PM   #5136
Azzkikin's Avatar
What's the shaft size on that pinion? I don't think it'll take a 540 motor shaft.
Old 01-07-2017, 02:50 PM   #5137
It will. Lots of people use them.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 01-07-2017, 03:14 PM   #5138
Trader Rating: 18 (100%+)
Those work well. Also go to www.175rc.com. They have a full range of polymer pinions. Been running them in my buggy and truck without any issues.
Chris Brown is offline   Reply With Quote
Old 01-07-2017, 05:12 PM   #5139
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by PerryCodes View Post
Could someone with wiki-editing perms please add this link:
https://www.youtube.com/watch?v=Jj3eIe6VneM
Such a great video!! Thanks AE!
Maybe better suited for the B64 thread...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 01-07-2017, 05:21 PM   #5140
denon's Avatar
Default Building Transmission
I am back in business with the new outdrive. I am just about to button up the transmission and it shows 6591 Diff lube on the gear diff. How much should I put in? Just a drop or two? Thanks!
B6 | SC5M
denon is offline   Reply With Quote
Old 01-07-2017, 06:13 PM   #5141
AccessRacer's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Chris Brown View Post
I'm running the Schelle long rear tower with the short shock eyelets and the shocks in the front of the arm. I want to try the shocks on the rear of the arm. Do I need to run the long shock eyelet when running the shocks in the rear of the arm with the Schelle long shock tower?
Run the short on the front and the rear when using the Schelle Tower7
AccessRacer is offline   Reply With Quote
Old 01-07-2017, 09:02 PM   #5142
sport10's Avatar
This will be an interesting experiment. Let us know the results.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 01-07-2017, 09:20 PM   #5143
Logi Maker's Avatar
"Problem" solved...
http://www.shapeways.com/product/TUT...ionId=61518278
Kyle Predmore
Old 01-07-2017, 11:12 PM   #5144
Or you take a wing without mounting holes, hold the leading edge 10mm from the shock tower, Mark it and drill the holes from there. Don't let the dimples in the wing scare you
Old 01-07-2017, 11:46 PM   #5145
Phillip F's Avatar
cheapest alternative.
Currently Active Users Viewing This Thread: 8 (4 members and 4 guests)
Chr1s, jomendoza2012, mschumi101, Rebuke
