    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree325Likes
Old 01-05-2017, 09:58 AM   #5116
WE have switched to AKA Rebars they changed it to loose dirt instead of clay. I believe other tires will also work.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 01-05-2017, 12:48 PM   #5117
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Originally Posted by caffeine357 View Post
Im trying to setup my B6d for an outdoor race. would these all work together for front wheels? if not what setup would you guys suggest? im not partial to any tire or wheel brand. just dont want to order the wrong stuff.
http://www3.towerhobbies.com/cgi-bin...?&I=LXDHJY&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXBZEJ&P=7
http://www3.towerhobbies.com/cgi-bin...&I=LXFEXF&P=7#
http://www3.towerhobbies.com/cgi-bin...&I=LXDVKZ&P=ML
This is the wheel you want, I chose the DE wheel because that's what you had. The Plus is the 60mm/2.4 wheel. This is the 2.2 wheel that works with the tires you had picked out. Good luck.
Jon Carlson is offline   Reply With Quote
Old 01-06-2017, 09:03 AM   #5118
Trader Rating: 29 (100%+)
Originally Posted by cementsurfer86 View Post
If the case doesn't work, that'll be the next step. The case should be in today, so we shall see.
Hope your new case worked out
Skeeter36 is offline   Reply With Quote
Old 01-06-2017, 11:16 AM   #5119
Any word on when the RDRP Brass Gearbox Brace will be available? There were press releases on it, but nothing is on Amain yet?
Bomba is offline   Reply With Quote
Old 01-06-2017, 03:11 PM   #5120
Pinkz's Avatar
how dare Amain not carry something that was announced 18 days ago!
It rubs the lotion on its skin or else it gets the hose again.....Yes, it will, Precious, won't it? It will get the hose! https://www.youtube.com/watch?v=cyn0DVSn96I
Pinkz is offline   Reply With Quote
Old 01-06-2017, 04:42 PM   #5121
Thrifty's Avatar
Any of y'all run sway bars on an indoor clay track? If so, what did you find out?
Tekno 410.3 SL
RC10-B6D
RC10-B6
RC10-B64D
AuperD rwd drift.
Thrifty is offline   Reply With Quote
Old 01-06-2017, 05:02 PM   #5122
Only way the car works imo. We run em front and rear, and we run the thinnest ones. They make a huge difference on this car if you have it setup laydown
Old 01-06-2017, 05:12 PM   #5123
Thrifty's Avatar
Good to hear... I picked some up and put them on tonight.. the thinnest one up front just seemed to limit droop but didn't offer any resistance on up travel.. changed out to the mid. Rear has the thin.
This is just desktop adjustments as it won't be till next week when I can get out to run it again...
Tekno 410.3 SL
RC10-B6D
RC10-B6
RC10-B64D
AuperD rwd drift.
Old 01-06-2017, 11:20 PM   #5124
Trader Rating: 25 (100%+)
Forgive me if already mentioned but what are people liking for steel chassis weights? I'm indoor high traction stock. Thanks.
jonnymorrow is offline   Reply With Quote
Old 01-06-2017, 11:32 PM   #5125
Skeeter, I ordered a new case and idler gear, which should be here on Thursday. Hopefully that'll fix it. I tried massaging and dremeling the case in all sorts of places but couldn't get it to go away.
It only happens when you put the two halves together, and I narrowed it down to the rub coming from the top-shaft area.
I ended up having to get a new case but make sure you set the bearings in as deep as possible. Seat the bearings lightly by hand and then use a 7mm driver to seat them in fully. You'll want to lay the case sides on something flat and hard and push as hard as you can to set them fully. See how that goes..
I was so frustrated I created my own thread for the issue here:
B6D Laydown Conversion internal Rubbing Issue
Hope it helps!
remix is offline   Reply With Quote
Old 01-07-2017, 12:39 AM   #5126
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Andrew Selvaggi View Post
Morning/Afternoon/Evening all, by request from racers I have created a new maintenance edition of the B6 Aussie Builds Blog. In this we go through some tips and step by step instructions on key rebuild items to keep your car performing at its best between races and in between race meets.
https://aussiebuilds.wordpress.com/2...-health-check/
As always feel free to hit me up with any questions or comments.
really appreciate your tips and videos. Good to see different workflows in maintenance.
Phillip F is offline   Reply With Quote
Old 01-07-2017, 02:32 AM   #5127
Trader Rating: 18 (100%+)
I'm running the Schelle long rear tower with the short shock eyelets and the shocks in the front of the arm. I want to try the shocks on the rear of the arm. Do I need to run the long shock eyelet when running the shocks in the rear of the arm with the Schelle long shock tower?
Chris Brown is offline   Reply With Quote
Old 01-07-2017, 04:10 AM   #5128
Already available at DMS Racing in the U.K.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 01-07-2017, 04:12 AM   #5129
eper's Avatar
Trader Rating: 14 (100%+)
Ok guys I have a b6 lay down car that is dam dam good. The only thing I noticed was the when you put the rear shock on front of the tower u are moving the wing forward the thickness of the tower mount. I'm guessing about 6 mm has anyone tried running the wing way back in close to the position it would be in with shocks on the back of the tower? I think I. Gonna try it just to see. I'd emagine it would have more of a effect on high speed rear traction but that's probably it. And it might make it jump more nose high. If anyone's plated with this I'd like to hear your opinions. Thank you
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is online now   Reply With Quote
Old 01-07-2017, 06:29 AM   #5130
It's been offered as a tip by BT and the team to run the wing about 10mm back of the tower when running shocks in front of the arm.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Big_Show
