    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree361Likes
Old 01-02-2017, 01:10 AM   #5071
Phillip F's Avatar
Trader Rating: 17 (100%+)
Originally Posted by RAP66 View Post
Finally finished... for the most part caught up on this thread. I have a B6... What the consensus on the rear shocks?? stock position or flipped to the rear of the shock tower?
-Rich
high grip , smooth track...front. Bumpy and inconsistent traction....rear.
Phillip F is offline   Reply With Quote
Old 01-02-2017, 07:00 AM   #5072
protc3's Avatar
Originally Posted by 1/4milecrazy View Post
Okay, so you have me convinced to try it. I am gonna try it with the MIP axles as I do have pucks in the car now.
Only problem is I can not find the BMI spacers. Ive googled everything I could to try to find them and have no idea what they look like or what they do even. Their website is terrible, the online store does not work and their facebook page doesnt seem like its been used in years. Any help would be greatly appreciated.
Yes, I know. My website has not been used in a long time. I used to make pan cars and stopped doing them 5 years ago. I check the Facebook page but have not been on this weekend due to a busy New Years weekend. I will be back in the office tomorrow so best bet is to shoot me an email and I will get you what you need. My email is [email protected]. Just give me until the morning to send you all of the info. We are off today.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-02-2017, 09:48 AM   #5073
Will these bmi inserts fit the new schelle b6 hubs?
Support your local track!!
rpc07 is offline   Reply With Quote
Old 01-02-2017, 10:07 AM   #5074
Are the BMI inserts used in the aluminum hubs?
Sean B. is offline   Reply With Quote
Old 01-02-2017, 10:11 AM   #5075
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Yes, they will only work with the aluminum hubs. Either the AE or the Schelle.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-02-2017, 10:12 AM   #5076
Or front position with the longer 31mm B5M Kashima shocks.
B64D | B6 | T5M | EB48.4 | Talion | EMB-TGH | Sakura Advance
daedalus is offline   Reply With Quote
Old 01-02-2017, 10:14 AM   #5077
AE aluminum hubs or shelle only?
Trinity/Revtech
brian mills is offline   Reply With Quote
Old 01-02-2017, 10:15 AM   #5078
Super Moderator
Either....
Old 01-02-2017, 10:16 AM   #5079
Sorry I just now read your entire post..
Trinity/Revtech
Old 01-02-2017, 10:56 AM   #5080
How loose should the front and rear arms be ? My front arms will drop all by themselves when I pick them up, the rear ones will not (brand new, only half way thru the build)
I know When i built my Tekno vehicles it stated in the manual to ream the arms, the associated manual does not
weedsnager is offline   Reply With Quote
Old 01-02-2017, 11:22 AM   #5081
1/4milecrazy's Avatar
Awesome, thanks for the reply. I have noticed that there are two facebook pages, the one that your website links to seems like an older one that is no longer used, but a search for BMI racing leads to a more current one.
I will be in touch. Now realizing that it only works with the Aluminum hubs has me second guessing because I dont have them. I have a pair on my SC5M but not sure I want to run them on my 17.5 car. I guess it cant hurt to try them.
Apparently "equal" and "partners" means different things to different people.
1/4milecrazy is offline   Reply With Quote
Old 01-02-2017, 11:24 AM   #5082
Racerx336's Avatar
Trader Rating: 34 (100%+)
Originally Posted by RC*PHREAK View Post
They have bones for the losi's but it doesn't state their length.
MIP 16131 are the aluminum axles you want if you are running pucks or rollers with the BMI offset inserts. They are on my cars right now. You also eliminate the spacers on the axle with these bones.
-Andrew Clark-
/ Nemo Racing USA /Agama / Pro-line Racing / VP Powermaster / RC Shox / Triton RC / Dutch Oven Designs / Paradise Air / TIX RD /
Racerx336 is offline   Reply With Quote
Old 01-02-2017, 11:33 AM   #5083
Trader Rating: 18 (100%+)
The new exotek titanium losi axles work as well.
Chris Brown is offline   Reply With Quote
Old 01-02-2017, 01:59 PM   #5084
protc3's Avatar
https://m.facebook.com/bmi.racing.5?...urce=typeahead
This is my page on Facebook. You can also look me up by name which is Jason Breiner. I try to do updates of products on both pages
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-02-2017, 02:25 PM   #5085
Newbie question:
I am building a set of 31mm shocks and followed instructions per manual (middle of page 15 steps 1-10) and I am getting a stroke length measuring 18.5mm. What am I doing wrong? Thanks in advance!
FDDA15 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 7 (2 members and 5 guests)
motorcitymatt, slowbiker
