    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 01-01-2017, 01:04 AM   #5041
Thanks for the replies guys - it's actually a ball diff I'm fitting the lay down kit in the b6d. Where would it need shimming - I didn't see it mention needing them in the manual. Thanks!!
Best way to describe it is it spins freely then feels like it's rubbing against the inside of the transmission case for around an 1/8 of a turn of the out drive.
remix is offline   Reply With Quote
Old 01-01-2017, 01:28 AM   #5042
can people please post what the steel weights weigh? trying to work out what i need to get for high bite indoor carpet...im at 1428 fully loaded with a slim shorty
servo weight
electronics weight
battery weight
brass front bulkhead
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Old 01-01-2017, 07:51 AM   #5043
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
servo weight
electronics weight
battery weight
The weights of each individual part are available at RC10.com
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-01-2017, 07:53 AM   #5044
Super Moderator
No shimming is necessary with the B6 ball diff. Did you use too long of a screw bolting it to the chassis? This can cause the inside of the case to get warped.
Old 01-01-2017, 08:32 AM   #5045
Trader Rating: 23 (100%+)
I have done that before! I locked up the transmission completely. LOL
I would check the teeth, and in between the teeth, on the gears. It is wired it is only for 1/8 of the rotation.
sstretch is offline   Reply With Quote
Old 01-01-2017, 10:08 AM   #5046
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
I will post my B6D setup later today for very high bite clay. Local track is clay with dirt glue. Clay slicks, mega grip.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 01-01-2017, 11:28 AM   #5047
Can someone go over why come guys are running TLR dogbones in their b6s?
Clydeywidey1 is offline   Reply With Quote
Old 01-01-2017, 11:41 AM   #5048
aeRayls's Avatar
We are running the 67mm bones combined with the offset rear hub bearing spacers that move the bearings and axle out 1.5mm. The longer bones get the driveshaft back into outdrive in the proper spot. This combination on the laydown car makes the rear end squat real hard under acceleration. Gives more grip under power.
aeRayls is offline   Reply With Quote
Old 01-01-2017, 11:54 AM   #5049
part numbers pretty please!
jeffb is offline   Reply With Quote
Old 01-01-2017, 12:01 PM   #5050
aeRayls's Avatar
Just search Amain for the tlr 67mm bones
THe offset hub spacers come from BMI racing
Old 01-01-2017, 12:02 PM   #5051
aeRayls's Avatar
Also forgot to mention that we also switch to the AE 5mm or 6mm rear hexes.
Old 01-01-2017, 12:10 PM   #5052
thanks I will take a look
Old 01-01-2017, 12:19 PM   #5053
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
Will these work for us?
https://www.amainhobbies.com/team-lo...232059/p553890
Or really, are there any bone options for the wide pivot that will allow the use of the MIP diff (aluminum outdrives)? Like maybe these:
https://www.amainhobbies.com/exotek-...xo1708/p543356
RC*PHREAK is offline   Reply With Quote
Old 01-01-2017, 12:34 PM   #5054
Anyone have issues with the lay down gearbox rubbing internally? My outdrive and idler gear are having an issue when I mate the halves of the transmission - if I hold the rear of the gearbox open a fingernails worth with the rest snug - no problems though.
I should mention this is the lay down kit in for the b6d (ball diff)
Here are some videos to show what's going on better.
Video 1 shows internals:
youtu.be/iWVKAmmfibg
Video 2 shows transmission moving smoothly when open a tiny bit in the rear and then how it runs when closed.
youtu.be/FMz12kr3dUI
Thanks for all the help!
Old 01-01-2017, 12:41 PM   #5055
Super Moderator
There are no obvious signs internally that could be causing the issue? Are those cut gears? Could be an issue there...
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
