    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 12-30-2016, 08:31 AM   #5011
Azzkikin's Avatar
Outside of the body, wing, battery brace and battery, this is what you can get with no aftermarket parts.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 12-30-2016, 10:08 AM   #5012
jabroni racing's Avatar
Trader Rating: 37 (100%+)
Send a message via Yahoo to jabroni racing
DANG
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 12-30-2016, 11:01 AM   #5013
Looking good...I start my build today !
weedsnager is offline   Reply With Quote
Old 12-30-2016, 02:06 PM   #5014
My kit arrived onThursday...I've been planning on starting it today. Wife is working a 12 hour shift, kids are busy with Their friends...hours and hours of free time...step one, bag one
Someone in China forgot to thread one of the posts
Old 12-30-2016, 02:09 PM   #5015
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Just push it on...
Disregard that 1 ball stud and press on.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-30-2016, 02:15 PM   #5016
Trader Rating: 17 (100%+)
I just built a b6 gear diff and wow so smooth. Last week inbuilt a gear diff for my Rb6.6 and that must be the worst design and feel when built. Humans up again for team associated.
Rcforlife13 is offline   Reply With Quote
Old 12-30-2016, 02:25 PM   #5017
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
look for your extra bag with extra hardware. should have 1 extra
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 12-30-2016, 02:26 PM   #5018
mdwaeracer's Avatar
extra one in little bag of extras
Old 12-30-2016, 02:55 PM   #5019
Box stock with a 4000mah SMC battery = 1528g
with a 2600mah LRP battery = 1460g
Dangit, I am also not running the stock body or wing with the light battery. Ok, it's official, I bring nothing to the table.
good one. mine came in at 1485g with a Orion 3800mah, Schelle Hubs, and the 25g brass C block! Car is light.
hsp-sandiego is offline   Reply With Quote
Old 12-30-2016, 03:30 PM   #5020
Phillip F's Avatar
That sucks. Yiu should contact team associated so they can send you one. I started mine last night and stopped at page 8. Bag 9-10.
Phillip F is offline   Reply With Quote
Old 12-30-2016, 04:14 PM   #5021
I called em, they are sending out a new one
Old 12-30-2016, 10:01 PM   #5022
Hey there - I am very new to this rc world! I've spent hours reading on here - some great info but then again this thread does span hundreds of pages so forgive me if this has been asked..
I have the b6d and purchased the lay down transmission for it - since I won't be running the standup for the rear setup should I follow the b6 team kit setup instead of the b6d?
I'll be running on tight track, high traction clay, with slicks and a coating of traction compound. Thanks for the help!!!
remix is offline   Reply With Quote
Old 12-30-2016, 10:18 PM   #5023
Super Moderator
Go check out Kurt Wenger's setup on petitrc.com. The B6 setup is geared towards high traction carpet conditions. Kurt's setup is a great starting point.
Old 12-30-2016, 10:23 PM   #5024
Thanks Matt! I'll have a look!
Old 12-31-2016, 01:28 AM   #5025
Trader Rating: 29 (100%+)
If you need a setup for high traction clay let me know. Send me a dm and I'll shoot it over to ya.
Skeeter36 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 7 (2 members and 5 guests)
2dialed, Screech
