    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 12-27-2016, 07:39 PM   #4966
Trader Rating: 25 (100%+)
Hey guys. Sorry if noob question but can someone list any differences (if any) between the B6 and B6D BESIDES laydown, diff and arms/towers. Thanks!
jonnymorrow is offline   Reply With Quote
Old 12-27-2016, 08:14 PM   #4967
Phillip F's Avatar
Trader Rating: 15 (100%+)
Spur gear is covered in the D ... the B6 gears are all exposed.
Phillip F is offline   Reply With Quote
Old 12-27-2016, 10:32 PM   #4968
tsair's Avatar
springs, shock fluid, caster block bushings
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 12-28-2016, 12:01 AM   #4969
Trader Rating: 29 (100%+)
Dude tbh they are the same car with a group of parts swapped. One can be built into the other and so on. If you race on med grip start with the D. If you race on super high like carpet then start with the 6, start there and then shape it into what you would like
Skeeter36 is offline   Reply With Quote
Old 12-28-2016, 06:24 AM   #4970
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
Originally Posted by GasGod View Post
anyone try alum shock towers? thoughts un these?
if you mean the VRP towers people seem to be liking them. I got some here to try myself.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 12-28-2016, 06:53 AM   #4971
Trader Rating: 35 (100%+)
let me know how they work out, was waiting to see some feedback on the towers. was kinda reluctant to try them as carbon towers flex more
CRaZeD is offline   Reply With Quote
Old 12-28-2016, 08:18 AM   #4972
Tech Legend
Cain's Avatar
There is a variety of posts in here about them. In general seems people like them that have them. Thats how I based my decision to get them. Plus the 30% of that VRP had at black friday helped too
Old 12-28-2016, 10:53 AM   #4973
Azzkikin's Avatar
A few days ago I asked if anyone has figured out a way to use the LRP Super Shorty battery in this car. Well I have figured out the battery brace (Part# HBS116257) from a Hot Bodies D216 works very well. I have full range of all the positions just like the normal battery brace would. It also comes with the link and hole in the brace to remove the waterfall. Now the link wont work for the transmission part, you just have to use your own lower shock connector like normal.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 12-28-2016, 11:55 AM   #4974
Eli
Eli's Avatar
I have not tried them but last week at the track there was one bent up pretty good on the pit table.
Eli Westrup - SDRC Raceway
Eli is offline   Reply With Quote
Old 12-28-2016, 02:46 PM   #4975
The Fox's Avatar
I have a question for everyone, I recently got a B6 laydown car and when I was building it there was a lot of hand fitting parts and things that dont line up right. For example, the rear hinge pin mounts, they are super tight and take a good amount of work to get them to install, you have to loosen both screws and go back and forth to tighten it down to the chassis. Another was the screws that hold down the transmission, you have to torque the transmission case to line up some of the last holes. I have heard from a few others that these cars are better quality(materials and included parts) but they also say that this is one of the worst cars from AE in terms of overall quality control. I had to do a lot of hand fitting like the above or having to file down parts to make them fit and not bind. What has everyone else's opinions been?
With Such A Wealth Of Information, Why Are You So Poor?
The Fox is offline   Reply With Quote
Old 12-28-2016, 02:57 PM   #4976
I thought the build was sweet. I did dremel polish all of my hinge pins and ball studs though. also used my hitachi to drive 95% of the screws.
here is a link to check out some build tips including polishing.
I have @ 30 packs on mine - broke the front bulkhead (thats a first) - nothing else.
hsp-sandiego is offline   Reply With Quote
Old 12-28-2016, 04:28 PM   #4977
The Fox's Avatar
Good link but none of that was the problem. I normally do but I decided against it since I am kind of lazy this build and planned on having to do an overhaul soon since I am coming back from a long break from the hobby. The car has run well and been very tough so far. Just the building was kind of a pain. C-blocks had to be filled down a few thousands to allow the steering to not bind. The arms dont bind but it is really a good amount of force to get the rear mount to fit, just stuff like that.
Old 12-28-2016, 04:36 PM   #4978
denon's Avatar
Default Arm Mount Insert Question
I am confused by what the stock setup should be for the rear arm mount inserts. Is it the one with the hole directly in the middle (just a dot on the back as listed in the back page?) or is it using the 1 with them facing the outside as in step 1 of bag 9-10? Thanks in advance.
B6 | SC5M
denon is offline   Reply With Quote
Old 12-28-2016, 04:51 PM   #4979
Thrifty's Avatar
Center dot on both.
Tekno 410.3 SL
RC10-B6D
RC10-B6
RC10-B64D
AuperD rwd drift.
Thrifty is offline   Reply With Quote
Old 12-28-2016, 08:52 PM   #4980
Who has the most worn out dog bones and what is the negative on performance?
My dog bones are now flat plates about 1mm thick.. its funny.. but the B6D seems fine?
twistedneck is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Kurtracing
