    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 12-26-2016, 09:21 PM   #4936
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Stock setting would be center on both. As long as both C & D inserts are in the same orientation you have 3 degrees toe and 1 degree anti squat.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-26-2016, 09:36 PM   #4937
1/4milecrazy's Avatar
There is no right or wrong. It depends on what settings you want on your car. That is why they make it adjustable so you can do whatever you want,.
Apparently "equal" and "partners" means different things to different people.
1/4milecrazy is offline   Reply With Quote
Old 12-26-2016, 09:53 PM   #4938
Just trying to get the box stock settings as a baseline.
B64D | B6 | T5M | EB48.4 | Talion | EMB-TGH | Sakura Advance
daedalus is offline   Reply With Quote
Old 12-27-2016, 12:22 AM   #4939
Phillip F's Avatar
Trader Rating: 17 (100%+)
Need help ..... rear left tire breaks loose after landing a triple-double jump ..then punching to enter a left turn sweeper. Running a gear diff(4K) and rear shocks with 27.5 wt (Kyosho green springs) and front 30wt (grey springs) . It only happens on that spot all the time.
It won't happen if I coast the sweeper (after landing) a little bit and straighten up the front end then punch. I feel like I'm loosing a lot of time by doing this.
Suggestions?
Phillip F is offline   Reply With Quote
Old 12-27-2016, 12:38 AM   #4940
Trader Rating: 29 (100%+)
Suggestions?
Carpet track?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 12-27-2016, 01:20 AM   #4941
Phillip F's Avatar
Originally Posted by Skeeter36 View Post
Carpet track?
medium to high traction clay
Old 12-27-2016, 06:06 AM   #4942
Suspended
dominick i.'s Avatar
Trader Rating: 123 (97%+)
was at scvrc back in january after reedy race....great track....awesome traction.....cool layouts...had fun.
club racing is always great racing......
I am probably the only non sponsored racer in the usa.....:)
dominick i. is offline   Reply With Quote
Old 12-27-2016, 06:48 AM   #4943
ridgerunner1's Avatar
Trader Rating: 21 (100%+)
Our track is also high traction and i found that 7K in the gear diff is just right you may want to give that a try.
Mike Craig
A&E B5M - Viper ESC
New Home Track Tacoma TRCR http://www.tacomarc.com
RIP Beremerton RC race way
ridgerunner1 is offline   Reply With Quote
Old 12-27-2016, 08:05 AM   #4944
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
That rear block that has the sway bar mounts, for those getting this in an alloy how are you liking it as far as it adding weight to the rear end?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Cain is online now   Reply With Quote
Old 12-27-2016, 08:57 AM   #4945
Originally Posted by MikeGassRacing View Post
I'm running the mip bi-metal pucks system and having an issue where the left rear dogbone is binding up on the t-nut. I've tried switching to the standard associated t-nut with the same results. Not sure where I'm going wrong here any advice?
Have messed with the Tnut and still having the same issue
MikeGassRacing is offline   Reply With Quote
Old 12-27-2016, 09:15 AM   #4946
Are you running narrow rear pivots or maybe narrow pivots in conjunction with the CV spacers?
Tijuana_Taxi is offline   Reply With Quote
Old 12-27-2016, 09:21 AM   #4947
Super Moderator
What pills are you running in the c&d block? If running an inside pin location it could be moving the axle too far into the outdrive. You would have to move the pin back out.
Old 12-27-2016, 09:29 AM   #4948
That would be my issue then thank you. Actually decided to pull the washers out of the outdrives and this fixed the issue also
Old 12-27-2016, 10:06 AM   #4949
Super Moderator
Washers out of the outdrives?
Old 12-27-2016, 10:38 AM   #4950
B44
B44's Avatar
I think it maybe this #91605 cva axle shims
B44 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
dswear22
