    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree328Likes
Old 05-14-2016, 03:47 PM   #481
Originally Posted by RCBuddha View Post
done
Awesome.
I found these on bookiewook;
Hartson
Numedahl
boucher is offline   Reply With Quote
Old 05-14-2016, 05:35 PM   #482
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/05/avid-b6...-bearing-sets/
RCBuddha is offline   Reply With Quote
Old 05-14-2016, 08:15 PM   #483
Jpdanger's Avatar
What is the purpose of Hartson using both channels to charge one battery?
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 05-14-2016, 08:18 PM   #484
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
60-80+ Amp charge and discharge when they are both hooked together.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 05-14-2016, 09:09 PM   #485
55Guy's Avatar
Trader Rating: 56 (100%+)
has any one found a promo code for the Team Associated RC10 B6 avid bearing kit yet
55Guy is offline   Reply With Quote
Old 05-14-2016, 10:01 PM   #486
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I love these bearings. Mine are 18 months old and still super smooth. I race indoors also
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-15-2016, 01:21 AM   #487
daverobbo5's Avatar
Trader Rating: 43 (100%+)
Well spotted! Furthermore, good question!!
daverobbo5 is offline   Reply With Quote
Old 05-15-2016, 02:42 AM   #488
abailey21's Avatar
Trader Rating: 36 (100%+)
See Kave's response above
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 05-15-2016, 04:55 AM   #489
https://www.facebook.com/TeamAssocia...646381016864:0
After switching from the standup to laydown 3-Gear configuration, Brent Thielke sets the fastest time in 40+ 2wd Modified Buggy with his Reedy Powered #B6D.
eddie7978 is offline   Reply With Quote
Old 05-15-2016, 05:49 AM   #490
DennisNyholm's Avatar
Can't wait to see these running at local track.
DennisNyholm is offline   Reply With Quote
Old 05-15-2016, 06:14 AM   #491
SAMCRO's Avatar
Default C and D mounts
Are the C and D mounts the same on the B6D as the B5M?
SAMCRO is offline   Reply With Quote
Old 05-15-2016, 06:33 AM   #492
RCBuddha's Avatar
No
Old 05-15-2016, 10:40 AM   #493
Suspended
Trader Rating: 61 (100%+)
No
You sure?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 05-15-2016, 10:52 AM   #494
RCBuddha's Avatar
Originally Posted by Socket View Post
You sure?
Old 05-15-2016, 12:28 PM   #495
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You sure?
They are not the same....move along...😏
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
djblues11, Stealthpilot, Still Bill
