Team Associated B6 & B6D thread
#4891
Rear camber link mount upper hub inserts breaking
I keep crushing in and breaking the rear camber link mount on the upper side of the rear hub.
It's that weak plastic insert that goes on the rear side of the blue aluminum five hole.
It's gotten better since I added larger washers on both sides.. but the tell tale sign is suddenly my rear camber is off.. I look and that plastic insert waffle looking thing is crushing in. Every time.. and you cannot get inserts w o buying hubs.. this is madening for me. Am I missing something??
#4892
#4893
Hey guys, need some bearing help. I installed some Avid Ceramic bearings in the B6, but I noticed the front wheeels didn't spin very much. Took it apart, added some Parma bearing oil to the bearings, and it seemed to be a little better. But the kit bearings seem to be a lot more free. The wheel spins longer with them. Avid tells me the bearings are packed with grease and ready to go, but I suspect I should be cleaning them and oiling them. What do y'all do for new bearings?
#4894
I believe the kit bearings are oiled not greased, that is why they will spin more freely than the greased ones you got from Avid.
Greased has more resistance but requires less maintenance, since it stays inside the bearing longer.
You can clean the grease out and oil them but you will have to take them out and re oil them more often.
#4895
http://www.schelleracing.com/Schelle...ng-Set-SCH2208
#4896
Tech Legend
The V3 and the V3.1 from what I recall are also easier to connect the programmer card as on the V2.1 you need to pull the lead from the receiver if I recall correctly. V3 and V3.1 have a port you don't need to do that with. I think that was the main reason I picked up a regular V3 when it came up for sale cheap over the V2.1 I had here.
#4897
#4898
Just run them. The grease will not slow down your car. If you want really smooth spinning bearings, look at Schelle. They use a special thin grease that last longer than oil but spins more than Avid grease.
I switched to the older b5 inserts they have less holes and last longer. Also there's a company that makes carbon fiber inserts the company name is BBR carbon products. If u need a link let me know
#4900
Question regarding changes in axle height with the pills and/or hub spacers....
What does the change up or down do and when would one use each setting?
#4903
Solved the upper camber link insert issue (rear) .. too bad I didn't read the tread about using two aluminum inserts instead of a single plastic one. ahh well.
my fix? fill the void between the metal and plastic rear upper camber inserts with epoxy. That locked the inserts and washers in place! problem is i'll never adjust that again! i'll get the Schelle aluminum hubs next time.
Until then the easy fix for anyone else reading this is two aluminum inserts - skip that plastic one. if you don't change it, suddenly your camber will begin to float and you wont realize why the car isn't handling... until it finally fractures the plastic insert.
#4904
#4905
My apologies guys I spoke to the guys at bbr and they never put that part into major production as most guys ran the aluminum hubs. I for one like the plastic hubs I feel they give a little more grip and at my tracks I need that grip. U could message them and ask for a set and they may have some laying around they will send u. Again my opologies. Here's the FB link https://www.facebook.com/BBRCarbonProducts/
