    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree325Likes
Old 12-18-2016, 11:27 AM   #4831
Originally Posted by gmintimidator View Post
Thats interesting. Last time I used UPS, they charged me $35 to fill out the import. I found a stock spec 3.1 on Amazon and picked that up to get me going.
I use usps United States Postal service not ups.
turtle189 is offline   Reply With Quote
Old 12-18-2016, 06:13 PM   #4832
This is probably a dumb question but sorry im a beginner and thinking about buying the b6d so could someone link a complete tool set i would need to build the b6d and a good tool set to get me started into the hobby, thanks
SegregatedPanda is offline   Reply With Quote
Old 12-18-2016, 06:45 PM   #4833
Phillip F's Avatar
Trader Rating: 15 (100%+)
https://www.amainhobbies.com/mip-tho...mip9008/p14515
https://www.amainhobbies.com/mip-tho...mip9007/p14513
https://www.amainhobbies.com/team-as...sc1675/p437692
Just in case you use Robinsons pinion gears
https://www.amainhobbies.com/mip-tho...mip9001/p14504
body trimming
https://www.amainhobbies.com/protek-...k-8278/p456657
paint (if you want to be like Jason Snyder)
https://www.amainhobbies.com/tamiya-...m86001/p125344
Phillip F is offline   Reply With Quote
Old 12-18-2016, 11:01 PM   #4834
i LOLed
shdwboxn is offline   Reply With Quote
Old 12-19-2016, 12:26 AM   #4835
Trader Rating: 29 (100%+)
I'm in the process of getting back into the sport. I've got a B6D coming and I'm pretty unsure of the ESC to get. I plan on running indoor and outdoor offroad (carpet and dirt). The indoor track is open on the motor, commonly people are running 10.5 to 13.5. I always raced stock brushed stuff back in the day, so picking a new esc and motor is tough. I was leaning towards a HobbyWing XR10 Stock, but not sure if thats the right choice or not. I need to get some wheel time in before getting a really quick motor. I was thinking of starting with a 17.5 and getting smooth and consistant before going hotter. I'd like to hear what others are using and running given some of my info. Thanks.
Your on the right track bud, but if your like the rest of us and get hooked and then you eat sleep and breathe RC then it really makes more sense for you to just buy the xr10 pro or whatever the top tier is then you will never have to worry about what motor you decide to throw in. With the lower amp models you may get 5 min of run time and be fine heat wise but what will likely happen is you and your bud are out there practicing and before you know 12 min gone by and your thermaling(not a word) your esc which is no good.
Long story short spend the extra money and guarantee your happiness!
Skeeter36 is offline   Reply With Quote
Old 12-19-2016, 08:03 AM   #4836
Im not sure if this has been asked before, but does the B5M outer hub inserts fit the B6?
rcadict21 is offline   Reply With Quote
Old 12-19-2016, 08:09 AM   #4837
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Outer ball stud inserts yes. Toe inserts no.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-19-2016, 08:11 AM   #4838
thats a shame
Old 12-19-2016, 09:06 AM   #4839
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
I am using AE's original tool kit that had both metric and standard sizes. I like the fact the handle has a pass thru so you can get some extra torque if needed with another driver ran through it, at least, that is what I do
the MIP stuff I like as well, got the ball driver, however, wish they had a pass thru.
But for working on say the B6D, you may not need it at all. AE has a specific metric and hex nut tool set you could pickup that should cover you. They also sell an all in one hex driver handle with hex bits too that you can also use in a drill. That makes building so much faster.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 12-19-2016, 09:27 AM   #4840
Trader Rating: 23 (100%+)
Does a Spektrum S6240 fit in a B6D?
I was going to try one, but I think the wire/plug is in the way of the servo mount?
sstretch is offline   Reply With Quote
Old 12-19-2016, 11:30 AM   #4841
SMcD's Avatar
Trader Rating: 61 (100%+)
Yes that is a problem with that servo.
We Shall See
The Track Raceway, RCRNV, JMR
Team Jacobs Racing
YouTube: looking for turtles entertainment
B6D, X-1 2016, T4 2014 VTA, SCX-10 II
SMcD is offline   Reply With Quote
Old 12-19-2016, 09:36 PM   #4842
Trader Rating: 18 (100%+)
Has anyone run the BMI rear hub inserts with the new exotek HD puck bones? I know the bones are longer than the stock ones, just curious if they're long enough to run with the BMI inserts. Thanks.
Chris Brown is offline   Reply With Quote
Old 12-20-2016, 12:11 AM   #4843
tschenck's Avatar
Trader Rating: 110 (100%+)
Exotek makes those bones for the losi too. Just get the ones for the 3.0. They are 67mm.
Pro-Line/MIP/Team Scream Racing/Dirt Skins
Wolcott Hobby/RCHR
Losi 22 4.0 hobbywing xr10 pro stock spec, tsr 17.5
tschenck is offline   Reply With Quote
Old 12-20-2016, 02:38 AM   #4844
Trader Rating: 140 (100%+)
Just finished. SC5.6
francomang likes this.
slick1 is offline   Reply With Quote
Old 12-20-2016, 06:04 AM   #4845
Azzkikin's Avatar
Has anyone come up with a way to use LRP's Super Shorty in the B6D?
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Currently Active Users Viewing This Thread: 12 (2 members and 10 guests)
germanz28, volcanus
