    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 12-14-2016, 08:31 AM   #4741
Originally Posted by Jmuck69 View Post
Maybe to get more anti-squat?
It also looks like his C block inserts are all the way up and in.
Tijuana_Taxi is offline   Reply With Quote
Old 12-14-2016, 08:36 AM   #4742
Jmuck69's Avatar
Trader Rating: 14 (100%+)
The team have been running 1 degree up on the C &D pills lately. This would give you 3 degees toe-in and 1 degree antisquat and a HRC. Looks like he added .5mm spacer to give overall 1.5 degrees of antisquat for more forward bite. Looks like the grip was there but overall with the pill locations and such he was wanting more rotation in the corners on the tighter layout.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-14-2016, 08:54 AM   #4743
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
The team has been running 1 degree up on the C &D pills lately. This would give you 3 degees toe-in and 1 degree antisquat and a HRC. Looks like he added .5mm spacer to give overall 1.5 degrees of antisquat for more forward bite. Looks like the grip was there but overall with the pill locations and such he was wanting more rotation in the corners on the tighter layout.
What the heck are those tires?
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 12-14-2016, 08:55 AM   #4744
aeRayls's Avatar
When using the offset rear hub inserts and 67mm rear bones it makes the car squat real hard under acceleration and adds plenty of grip. Lately most of us have been using a tad more antisquat. That's what he was doing by using the .5mm shim under the c block.
aeRayls is offline   Reply With Quote
Old 12-14-2016, 09:03 AM   #4745
JConcepts Octagon
Old 12-14-2016, 09:23 AM   #4746
Jmuck69's Avatar
Actually watching the Jason interview with Spencer and he talks about the offset hubs AE is developing and mentioned it adds grip in all aspects. Can't wait to see when they come out.
B6D | B64D
Old 12-14-2016, 09:36 AM   #4747
Just finished watching it too. Seems like we're still kinda scratching the surface of what this car is really capable of. Scary considering how good it already is.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 12-14-2016, 09:53 AM   #4748
Mason's Avatar
Re: The shock pins Rivkin is using.
What's the diameter on those? I have been imagining something like this for years but never got around to doing something about it. So do I need to drill the screw hole larger?
Also, i don't know why he drilled the set screw hole right on top of the pin instead of two between each of the mounting holes. Just back out the screw - move pin, screw back in. Wouldn't need a 3rd like the way he does it.
Would be really bad *ss if it was a ball detent pin but there would probably be some material strength issues. (it would either require drilling the same holes to realize the function itself, or the pin would go all the way through the arm and detent at one end or the other.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 12-14-2016, 09:59 AM   #4749
Jmuck69's Avatar
Maybe he machined the pin diameter down to fit the stock hole or down to 3mm and drilled arm out. Also, could have relocated the recess in the pin to where he has it located.
Edit...Actually looks like he drilled the first hole larger and the second is smaller. Maybe stepped down diameter?
B6D | B64D
Old 12-14-2016, 10:12 AM   #4750
Trader Rating: 29 (100%+)
Originally Posted by Chris Reilly View Post
You would need to look at the hinge pin angle to know. If it lessens the angle it is the opposite of what you said. Otherwise you are right.
Raising the C block definitely creates more pin angle up at the front of rear hinge pin, which creates more anti squat but it also does something else
Skeeter36 is offline   Reply With Quote
Old 12-14-2016, 10:28 AM   #4751
Phillip F's Avatar
Link?
Phillip F is offline   Reply With Quote
Old 12-14-2016, 10:34 AM   #4752
Originally Posted by Phillip F View Post
Link?
https://www.youtube.com/watch?v=QZNzK_Vs6r4
Old 12-14-2016, 10:37 AM   #4753
Maxxingout's Avatar
Trader Rating: 15 (100%+)
Link?
https://www.youtube.com/watch?v=s1jKhC2PPrw
Tekno EB48.4, Hobbywing XR8Plus-1900kv
Tekno ET48.3, Tekin Gen2-T8-1900kv
Maxxingout is offline   Reply With Quote
Old 12-14-2016, 11:04 AM   #4754
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
since when did tebo start driving like such a d!ck? A1 and A2 several "questionable" pass attempts. 4:05 of A2 he looked like he just totally meant to drive through rivkin.
RC*PHREAK is offline   Reply With Quote
Old 12-14-2016, 11:26 AM   #4755
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Question for you guys, I picked up a B6D for my daughter that came with some upgrades like the schelle slipper setup. How much of a performance difference are you guys seeing running this setup versus running say some garolite style pads (Mckune, RC Shox) on the stock setup (I am running this works great). Trying to keep things similar between us so not maintaining one thing special. The garolite pads work excellent, no issues there, but if there are things to the schelle setup that are work keeping around I am game since it came with a whole lot of spur gears.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
kyosho_utah
