    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree369Likes
Old 12-13-2016, 10:04 AM   #4726
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
I know someone local who runs a lot of reedy stuff so looking forward to seeing the ESC.
Personally I am curious about maclan's new one with that micro usb port on it.
http://www.maclan-racing.com/product...tion-esc-160a/
don't know if its a copy of someone else, or vice versa, etc.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 12-13-2016, 12:26 PM   #4727
Originally Posted by Matt Trimmings View Post
You don't adjust for chassis stiffening. It just a battery strap that eliminates the waterfall and uses a turnbuckle. Similar to the Schelle and others out there. It does allow some finer adjustment of where the pack goes but the turnbuckle is just there to brace instead of the waterfall...you adjust the turnbuckle based upon where the pack is mounted...it is not its own adjustment.
Isn't the whole purpose of removing the waterfall to create more chassis flex?
RookieRacer00 is offline   Reply With Quote
Old 12-13-2016, 12:27 PM   #4728
Originally Posted by Scott R View Post
slipper too tight
Or diff too loose???
Old 12-13-2016, 12:30 PM   #4729
jmcelroy42's Avatar
I am curious to see how that one works as well.
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 12-13-2016, 12:36 PM   #4730
jabroni racing's Avatar
Trader Rating: 37 (100%+)
Send a message via Yahoo to jabroni racing
Originally Posted by Phillip F View Post
https://www.youtube.com/watch?v=xLbnYJ3gJ-0
One of the features of this device is that it helps you pinpoint what motor timing you need to be (for optimum performance) ...at a specific voltage....in this case 6.0 amps.
Just curious, where did the 6amps come from??? Ive had motor guys say they dont go by that???? do you basically crank the timing until it pulls 6amps
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 12-13-2016, 12:50 PM   #4731
Trader Rating: 18 (100%+)
Ito more of a reference thing. Since there isn't a load being put on motors there's no real way to synopsis the using the motolyser. People are tuning to the 6 amps because somewhere someone came up with that as the sweet spot for a particular motor. The only real benefit to tuning to a 6 amp draw is to compare kv from one motor to the next. Your best bet is to do good old fashioned testing. Don't be afraid to try different timing and gear ratios. Just keep an eye on Temps, lap times, and feel.
Chris Brown is offline   Reply With Quote
Old 12-13-2016, 01:17 PM   #4732
I believe that 6.0 ~ 6.5 comes from the experience of the guy in the YouTube video, but I'm planning to email him about it.
Having said that, this is my logic, based on my experience, which is less than Nick's:
Pulling more current from the battery is a good thing, as long as it's converted to motion rather than heat. This is due to power (in Watts) being equal to Volts x Current; if the voltage stays the same, and the current increases, the power increases as well.
When you measure the motor performance with the analyser, you're checking the KV rise and current rise as you increase timing. What you will see is that KV increases rapidly initially, and then the rate of increase starts to reduce, while the rate of increase for current draw starts to increase. What this appears to show is that there is a point where the motor starts to convert more and more of the electrical energy into heat, rather than motion, and this is what you'd want to avoid. Experience shows that this seems to be at the 6.0 Amps ~ 6.5 Amps area, for 13.5 and 17.5 motors in particular.
I guess for mod motors, this probably would be different, but you can use the ESC timing with mod motors anyway, and they're so much more powerful too. I'd be interested to test 21.5 motors for spec racing, but I'd not done that yet.
Nezil is offline   Reply With Quote
Old 12-13-2016, 01:43 PM   #4733
What he said.
Old 12-13-2016, 02:35 PM   #4734
Originally Posted by MrLean View Post
What are people's experience with these? I've used the old orange pucks before and was upset how much maintenance was required.
I've been using the roller pucks for several months now, I run 17.5 on turf. I have had zero maintenance for the pucks themselves, and the outdrives look brand-new. Car also seems to roll smoother.
For comparisons sake, my OEM outdrives were all chewed up after only a couple months of running.
Tobey457 is offline   Reply With Quote
Old 12-13-2016, 03:56 PM   #4735
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
It creates more side to side flex while maintaining the front to back flex.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-13-2016, 07:14 PM   #4736
JsK
JsK's Avatar
I would say the beam stiffness is going to be a bit more due to the mounting location, torsional rigidity should be less due to it being able to twist on the turnbuckle mounts
JsK is offline   Reply With Quote
Old 12-14-2016, 06:01 AM   #4737
Maxxingout's Avatar
Trader Rating: 15 (100%+)
Anybody notice that Spencer Rivkin was using a washer underneath his c-block at the JC indoor series race? Car looked super dialed in the videos.
http://site.petitrc.com/setup/associ...ivkinB6-13.jpg
Tekno EB48.4, Hobbywing XR8Plus-1900kv
Tekno ET48.3, Tekin Gen2-T8-1900kv
Maxxingout is offline   Reply With Quote
Old 12-14-2016, 06:33 AM   #4738
jmcelroy42's Avatar
I noticed that on Cole Tollard's car at our local turkey race too. Forgot to ask him about it.
Old 12-14-2016, 07:53 AM   #4739
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Maybe to get more anti-squat?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-14-2016, 08:15 AM   #4740
You would need to look at the hinge pin angle to know. If it lessens the angle it is the opposite of what you said. Otherwise you are right.
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
kyosho_utah
