    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree366Likes
Old 12-10-2016, 07:11 PM   #4696
Trader Rating: 17 (100%+)
2 questions. How many are switching to front rear shocks and why ?
And what are racers choosing to use more often. Standard servo or low profile short servo ??
Rcforlife13 is offline   Reply With Quote
Old 12-10-2016, 07:17 PM   #4697
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Originally Posted by dan-o View Post
Thanks redracerd- I appreciate it!
VRP should include something for guidance.
We will be putting instructions on our website. We just didn't have any instructions ready when we shipped out this batch. I apologize.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 12-10-2016, 07:23 PM   #4698
Trader Rating: 90 (100%+)
Parts fit well , machining is very good!! this will complete the kit to being perfect
dan-o is offline   Reply With Quote
Old 12-10-2016, 08:33 PM   #4699
Okay gents, I just bought MIP Roller Pucks™, Gear Diff Kit, All AE B6, #16040. For the gear diff, do I still use the spacers MIP provides? Or is that just a ball diff thing?
BruceR. is offline   Reply With Quote
Old 12-11-2016, 06:29 AM   #4700
Hey everyone, My brother and I both picking up the B6D kit and are looking for advice on a motor esc combo. I would like to try and stay below 200 bucks if possible.
I currently have a CC Sidewinder SCT and really enjoy it in my 22 sct 2.0. I cannot tell a difference between that and my sensored tekin rs gen1.
My local track appears to run mostly mod class but i would like to be able to drop a stock motor in to race at other venues.
I was thinking the below setup.
https://www.amainhobbies.com/castle-...066-06/p156433
TLR 22 SC 2.0
RC10B44.3
TLR 8ight 3.0 Electric Converted
Traxxas/RPM Rustler
RC10B6D w/ Laydown
caioz1jp is offline   Reply With Quote
Old 12-11-2016, 07:19 AM   #4701
Reedy 1000Z is a good affordable ESC that's easy to program and you can put any motor on it down to a 5.5. Their motors are good too. My son is running the 1000Z with a 17.5 Reedy motor with no problems this year
http://www.amainhobbies.com/reedy-bl...sc258c/p512325
roysays is offline   Reply With Quote
Old 12-11-2016, 07:47 AM   #4702
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
The 1000z combos only come with modified motors, if wanting to go with a stock setup the 800z is available with a 17.5 motor. Both are easily adjustable esc's.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-11-2016, 07:52 AM   #4703
Super Moderator
In my experience (clay indoor tracks) mounting the shocks on the front of the rear arm gave me a little more rear traction and rotated quicker around the corner, the shocks on the back of the arm the car still had good rear traction but needed some help to get around tight corners. I was at first a little afraid to move them to the front because I thought it would take away bite but I was pleasantly surprised on how it felt. Takes 5 mins to change and is worth at least trying.
Servo wise, I felt that the front end had more weight than I liked with the full servo so I went low-pro and like it a lot better. Plus I can always add about 10g to get back to full servo weight.
Old 12-11-2016, 08:29 AM   #4704
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
This ESC would be a good option as it can handle some of the higher power mod options and isn't super expensive:
https://www.amainhobbies.com/hobbywi...112400/p279086
Then find a motor that suits you. I am liking the maclan line up of motors myself but there are other options, including some on the cheap for about $50 new.
I would also pickup there LCD Programmer personally just easier to do adjustments. Hobbywing also has more ESC options with more power, etc. depending on what you want.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 12-11-2016, 08:35 AM   #4705
Trader Rating: 22 (100%+)
I 2nd the Hobbywing XERUN XR10 Justock Cain mentioned. Can also grab one of the revtechs that are currently on sale for a nice $100 combo:
https://www.amainhobbies.com/team-tr...ev1600/p291998
chadp is offline   Reply With Quote
Old 12-11-2016, 12:34 PM   #4706
I wanted to thank everyone for the input. Are the hobbywings and Reedy that much better than the castle creation?
If that is the case I am looking at the following:
Again I want us to be able to do both spec and mod, mostly mod.
TLR 22 SC 2.0
RC10B44.3
Traxxas/RPM Rustler
RC10B6D w/ Laydown
Old 12-11-2016, 12:49 PM   #4707
suby723's Avatar
Trader Rating: 21 (100%+)
If you gave me castle for free i still wouldn't run it..
suby723 is offline   Reply With Quote
Old 12-11-2016, 12:52 PM   #4708
Super Moderator
^ That's probably the best answer for that question.
Old 12-11-2016, 01:05 PM   #4709
71schaeffer's Avatar
Trader Rating: 10 (92%+)
Guys do the B5 and B5M bi metal pucks work with the b6d? Our hobbyshop carrys the bi metal and not the 17.5 new pucks system on a main. They both say they can be used on B5M so i assume they would work. Thanks
Hobbytown USA Gladstone,MO / StickyKicks RC / Fantom Racing / Clints Creations
71schaeffer is offline   Reply With Quote
Old 12-11-2016, 08:44 PM   #4710
sport10's Avatar
Steer away from castle they have weak becs in their speed controls plus I would recommend a good sensored setup. The hobbywing v3.1 mentioned above is a great option.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
Fearo
