    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 05-12-2016, 07:38 PM   #451
Suspended
People always complain about traction. Tires win races and throttle control. Set up helps
Rc4life1978 is offline   Reply With Quote
Old 05-12-2016, 08:48 PM   #452
OriginalDonk's Avatar
Trader Rating: 41 (100%+)
Tires win throttle control? I had absolutely no idea.
OriginalDonk is offline   Reply With Quote
Old 05-13-2016, 03:39 AM   #453
Originally Posted by Rc4life1978 View Post
I'm going to rock my b5m ce which is still a winner on dirt and clay.
I think once people get these cars ur going to see people complaining on traction bc they r trying to make a carpet car race great on dirt. This isn't Europe
I didn't realize that this car was only for carpet...
boucher is offline   Reply With Quote
Old 05-13-2016, 05:28 AM   #454
Flip boy's Avatar
Someone said a page back, the b6d with the laydown will be the new norm roughly, heed that statement. Medium to high grip you will see the fast guys running a laydown all the time, especially in stock. So make sure you buy the laydown parts with your b6d if your surface is medium to high.
Flip boy is offline   Reply With Quote
Old 05-13-2016, 05:46 AM   #455
Originally Posted by Flip boy View Post
Someone said a page back, the b6d with the laydown will be the new norm roughly, heed that statement..
Ha I said that. I think that as we spend more time with these new platforms, we'll find that even with the weight of the car moved forward we can make them work and be fast on most surfaces. I just hope AE has enough stock of laydown parts because the demand is sure to be pretty high.
Old 05-13-2016, 06:24 AM   #456
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Or enough flat arms and towers for the "carpet car"... pretty sure I'm going that route. Off the see Spencer and Brent in a few...
Luckily Spencer carried on his car and radio because that is all he has.... damn airlines.
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 05-13-2016, 08:23 AM   #457
Gigasipke's Avatar
Spencer Rivkin on Clay with his B6/D
https://www.facebook.com/TeamAssocia...3642299676864/
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 05-13-2016, 11:22 AM   #458
Cridd's Avatar
Trader Rating: 16 (100%+)
B6D with laydown is going to be pretty close to B5M with laydown I would think. B6 looks to be a little less weight so we will be able to move those weights around as needed.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-13-2016, 11:30 AM   #459
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Yes, Like at my home track (Club RC in Houston), I will be running the B6D with laydown. Our track is smooth, High bite and coated with Dirt Glue. So mega traction.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 05-13-2016, 11:36 AM   #460
Finalist's Avatar
Will most people be changing the stock steel turnbuckles for Ti turnbuckles for 17.5 racing?
I'm thinking that's my first upgrade, but I have heard zero chatter/complaints about the kit not coming with titanium turnbuckles.
Finalist is offline   Reply With Quote
Old 05-13-2016, 12:34 PM   #461
Jmuck69's Avatar
I'm changing for Mod racing. Is it needed...no...but it's habitual for me to put titanium turnbuckles on. Kody indicated the car, with steel turnbuckles, is lighter than the B5M FL.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-13-2016, 12:45 PM   #462
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Indoor is basically done around here so excuse me for not being up to speed but..What do you gain, is different, running the B6d with the lay down vs. just running the B6?
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 05-13-2016, 12:49 PM   #463
Trader Rating: 18 (100%+)
The b6 has the gullwing arms and wider tower. Plus a gear diff. That's it.
Chris Brown is offline   Reply With Quote
Old 05-13-2016, 12:50 PM   #464
What the guys who have lay down transmissions in other platforms are saying is the lay down transmission is allowing for greater corner speed. It's another tuning option.
Old 05-13-2016, 01:34 PM   #465
I'm running my B5m with the ACRC 3 gear trans now. What I personally am looking for out of the B6-laydown-flat arms-ball diff is a similar feel in driving characteristics, but with the added benefit of all parts being OEM and not costing hundreds of dollars extra. I think that a purpose built car will perform better than our currently "aftermarket modified" B5m's.
Currently Active Users Viewing This Thread: 11 (1 members and 10 guests)
Allen Drebi
