    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree328Likes
Old 12-02-2016, 09:07 AM   #4561
Is everyone doing this mod? Just started my b6d build last night. Caught this on AussieBuilds blog site here
hsp-sandiego is offline   Reply With Quote
Old 12-02-2016, 09:12 AM   #4562
ibalderas's Avatar
Originally Posted by hsp-sandiego View Post
I am using the Losi servo arm with a Savox with no fitment or rubbing with perfect geometry and the kit setup. Sounds like issues when using the AE Aluminum servo arm.
im using the exotek servo arm NOT AE
ibalderas is offline   Reply With Quote
Old 12-02-2016, 10:18 AM   #4563
Originally Posted by sport10 View Post
Let me save you a little headache. Leave the spacer behind the servo ears and just remove the 2mm spacer behind the ballstud. This is the proper way to fit a savox servo in the B6! You will have fitment problems if you don't have at least one spacer behind the ears. The servo screws without the spacer will hit the plastic posts before the holes for the hold down screws line up. Unless you want to source shorter screws.
This post was right on time as I just purchased a 1258TG...do you remove the 2mm aluminum ball stud washer just for the Savox line of servos, or should it be taken off for all servos to get the servo 2mm forward?
FreeBandz is offline   Reply With Quote
Old 12-02-2016, 11:11 AM   #4564
Jmuck69's Avatar
I have heard this works great if the traction is really high since it takes away forward bite coming out of the turn on power.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-02-2016, 01:37 PM   #4565
Phillip F's Avatar
Trader Rating: 15 (100%+)
I did it. And it made a little difference. I think you can feel it more if you are running in dirt. I have a b6 and run on clay high bite track.
Phillip F is offline   Reply With Quote
Old 12-02-2016, 04:28 PM   #4566
stuey's Avatar
No we are just adjusting the roll centre with the top links axels plus getting the shock correct not seen one top class driver needing to do this
stuey is offline   Reply With Quote
Old 12-02-2016, 04:31 PM   #4567
sport10's Avatar
You need to evaluate the alignment for each different servo you use. I am also using a 1258tg servo.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 12-02-2016, 06:55 PM   #4568
Trader Rating: 32 (100%+)
Hi guys i have a question got confused TOE-IN / ANTI-SQUAT pill in manual
BLOCK D mounts (Center DOT) 3 toe -IN and BLOCK C mount (CENTER DOT) 1 Anti-squat
And this is my PILL
BLOCK D mount CENTER DOT 3 and BLOCK C mount 0.5 CENTER-UP what is the total of ANTI-SQUAT?
Can anyone clarify this sorry i can't understand this thanks guys have a great weekends everyone.
raved007 is offline   Reply With Quote
Old 12-03-2016, 01:26 AM   #4569
aeRayls's Avatar
And this is my PILL
You have 3 toe with 1.5 squat
This should be helpful:
https://www.teamassociated.com/pdf/cars_and_trucks/RC10B6D/B6_B6D_Pill-Chart.pdf
aeRayls is offline   Reply With Quote
Old 12-03-2016, 03:46 AM   #4570
eper's Avatar
Trader Rating: 14 (100%+)
The Kyosho front bulkhead comes with a square spaced that drops right in and is easier then 4 separate spacers. Also I have only been running the .5 and I like that but I haven't tried the 1mm yet. Just a heads up to make assembly easier
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 12-03-2016, 04:50 AM   #4571
https://www.teamassociated.com/pdf/c...Pill-Chart.pdf
Thanks for your response
Old 12-03-2016, 06:20 AM   #4572
Trader Rating: 42 (100%+)
I'm sorry, could you clarify...the Kyosho spacer will drop right into the b6d front end? If so, that does seem a lot easier.....would anyone happen to have a P/N? Thanks for the info!!!!
rccars4scott is offline   Reply With Quote
Old 12-03-2016, 07:36 AM   #4573
thecman26's Avatar
Trader Rating: 99 (100%+)
I think this is it?
https://www.amainhobbies.com/kyosho-...youm502/p13102
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 12-03-2016, 09:01 AM   #4574
jabroni racing's Avatar
Trader Rating: 37 (100%+)
Send a message via Yahoo to jabroni racing
Question, What does the Differnt size shock Cups do?? To me wouldnt using a thicker one be the same as turning the collar down more(tightening spring & raise ride height) ??
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 12-03-2016, 09:37 AM   #4575
Thanks a bunch. Ordered.
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
djblues11, Stealthpilot, Still Bill
