    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree326Likes
Old 11-21-2016, 07:06 PM   #4396
TonyWest's Avatar
Trader Rating: 50 (100%+)
Default What axle height are the alum hubs
Sorry if this has been answered already.
Thanks in advance for the answer.
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 11-21-2016, 07:18 PM   #4397
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
The 0 height.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 11-22-2016, 06:34 AM   #4398
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
odd question, do the AE blue annodized parts respond to the greased lightning trick of deanodize them. I prefer the black annodized look but some parts that are in blue I wouldn't mind just doing them in the silver look, polished up.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 11-22-2016, 10:09 AM   #4399
abailey21's Avatar
Trader Rating: 36 (100%+)
If you're looking at a blackout or different color contact motowhips, I believe they'll even do the removal for you??
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 11-22-2016, 12:35 PM   #4400
Tech Legend
Cain's Avatar
thanks. I shot them a message.
Old 11-22-2016, 02:37 PM   #4401
Wow those look great. Going to have to look into that.
Support your local track!!
rpc07 is online now   Reply With Quote
Old 11-22-2016, 03:31 PM   #4402
B44
B44's Avatar
easy off oven cleaner works great.
B44 is offline   Reply With Quote
Old 11-22-2016, 09:36 PM   #4403
Andrew Selvaggi's Avatar
Following on from my B6d build blog, there were a lot of requests to show a shock build. The 2nd post in my Aussie Builds blog will take you through a step by step process on how to build a 1/10 off road shock, easily and consistently.
Any questions don't hesitate to hit me up.
https://aussiebuilds.wordpress.com/2...f-road-shocks/
Team Associated ~ JConcepts ~ Hobby Wing ~ Team Orion ~ nVision ~ Sav÷x ~ Upgrade RC
Andrew Selvaggi is offline   Reply With Quote
Old 11-22-2016, 10:12 PM   #4404
tsair's Avatar
Nice video. I see there's no rebound, but are you getting suction at full shock extension when building the shocks this way?
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 11-22-2016, 11:39 PM   #4405
Originally Posted by awidz View Post
I run steel weights in both spots. Cavs setup minus brass bulkhead. Run on high bite carpet Offroad track. Car is Fast and handles great. Battery all the way back. White spring on rear, 1 lighter than cavs setup.
i see that he has the shocks on the REAR of the arm....is that how people are running his setup? my car already has too much rear grip, ESPECIALLY on corner exit
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Old 11-23-2016, 04:22 AM   #4406
Great video. Some good info!
Old 11-23-2016, 04:42 AM   #4407
Default 31mm rear shocks
I'm going to give the 31 mm rear shocks a try on my B6d. Has anyone compared the Schelle and associated shock towers? I know the associated tower is slightly taller and was wondering if there was any noticeable difference?
RookieRacer00 is online now   Reply With Quote
Old 11-23-2016, 05:27 AM   #4408
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/11/schelle-b6-strap-x-plate/
RCBuddha is offline   Reply With Quote
Old 11-23-2016, 05:50 AM   #4409
Tech Legend
Cain's Avatar
wonder how many other battery strap systems could get an adapter plate. My vehicle came with a carbon one that has the battery hold in "spacers" that get closer together on one side (not sure the brand) but the concept that schelle did looks the same.
Old 11-23-2016, 05:53 AM   #4410
Trader Rating: 16 (100%+)
About to buy a B6d and add the laydown conversion.
What other hop ups should I buy together for running on clay with slicks ?
Rcforlife13 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Dragon01826
