Team Associated B6 & B6D thread
#4351
R/C Tech Elite Member
Someone on the FB page was asking about a particular dudes wiring and how clean it was.
This may seem like a dumb question but it was brought up that "he's probably using a PCB board" and I just wanna know does that even exist??
Also with the draw of 17.5 not being a ton like mod has anyone tested smaller 16g wire like the 12th guys use?
#4352
Tech Legend
I haven't seen anyone using 16 gauge but 14 gauge I have seen used on other 2wd buggies, in particular for the connection to the motor.
Personally, I need my skills wayyy up there first before that will make a diff lol.
One thing you can look at too is that some 12 gauge wire as a much thicker rubber "sleeve" than other wire.
#4353
#4354
#4356
So what is everyone's opinion of slipper vs. locked for Stock racing? I run on medium to high traction clay and I've tried a few different sets of tires and made a few setup changes and it has got better but I still feel like I could use more rear grip on mid to exit of the corners, especially if there is a jump right out of the corner and I need to really get hard on the throttle to make the jump. I find myself losing forward traction and have been thinking it might be to running the slipper eliminator. I am thinking this weekend of throwing the slipper back on and trying it.
Other than that, I'm loving this car!!!
Oh btw, I am running the B6D with the laydown trans and shocks in front of the rear arms.
#4357
#4358
Thats exactly what i was looking for, I used to run the TQ 16 in my 12th and with the lower weights of 17.5 2wd these days I was figuring it "could" work.
#4360
Tech Legend
#4363
#4364
I run steel weights in both spots. Cavs setup minus brass bulkhead. Run on high bite carpet Offroad track. Car is Fast and handles great. Battery all the way back. White spring on rear, 1 lighter than cavs setup.
