    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree361Likes
Old 05-09-2016, 02:33 AM   #421
Originally Posted by _danimal_ View Post
Laydown gearbox 6.99
Laydown motor plate 13.99
39t idler gear 5.99
So, 27 bucks thereabouts.
You will Also need the B6 Waterfall. They are different lengths for each car.
Mxer210 is offline   Reply With Quote
Old 05-09-2016, 08:18 AM   #422
39t idler gear 5.99
Would you guys also want to go with the lower B6 wing mount and a wing without the shock cutouts? Would you guys also run the shocks in the front? I know, first things first and let's get the car in our hands, but I'm so excited about the true tangible tuning possibilities. Did Rivkin setup his Laydown transmission car with the shocks in the front?
dustneyes is offline   Reply With Quote
Old 05-09-2016, 08:22 AM   #423
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
he had them in front for carpet, but now has them in the rear for dirt
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 05-09-2016, 08:57 AM   #424
Nice to know. Thanks!
I imagine it would, but could you easily swap the gear diff for the ball diff in the Laydown?
Old 05-09-2016, 09:00 AM   #425
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
yes, they are interchangeable.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-09-2016, 09:05 AM   #426
5tone's Avatar
It looks to be as easily as usual with the B5M
no quick access like the xb2
5tone is offline   Reply With Quote
Old 05-09-2016, 09:07 AM   #427
not it will not be. I would have liked to have seen easier diff access..but it didnt happen
Old 05-09-2016, 09:10 AM   #428
Kody said on fb that they looked into it, but placed proper gear mesh as a higher priority.
boucher is offline   Reply With Quote
Old 05-09-2016, 09:14 AM   #429
Nothing that one of these won't make short work of...
https://www.amazon.com/gp/aw/d/B004Y...=ATVPDKIKX0DER
dsms4ever is offline   Reply With Quote
Old 05-09-2016, 10:54 PM   #430
Kegman21's Avatar
Hmm that would make a nice fathers day gift. Now how to suggest it to the wife?
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Old 05-10-2016, 03:30 PM   #431
Gigasipke's Avatar
Yeah, pre-ordered my B6D on Tower Hobbies. The only thing, is that it didn't show the $45 savings after I put in my Savers Club discount. It still showed the $309 price. Hopefully the discount comes off when the pre-order is filled.
Can't wait to get it, even sold my B5M for a good price.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 05-10-2016, 03:39 PM   #432
it applies it when the order is processed. it should say that in your email
Old 05-10-2016, 04:30 PM   #433
Gigasipke's Avatar
I just checked and the email states it in an odd way, but does say that.
Thanks,
Steve Aldous
Old 05-10-2016, 07:14 PM   #434
Logi Maker's Avatar
Trader Rating: 49 (100%+)
That is correct.... also watch for when it says it is in processing. When I pre-ordered my TC7 it had a $30 off at the time.... got an in stock email... noticed the new coupon for the month was $70 off.... canceled my pre-order and bought one right then and there with the $70....
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 05-11-2016, 10:29 PM   #435
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.neobuggy.net/2016/05/11/a...b6/#more-74698
RCBuddha is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
FISHNFOOL9, Wildcat1971
