    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree328Likes
Old 11-08-2016, 08:49 AM   #4261
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Cain View Post
question on the variety of chassis protectors, I forget the name of it but the one I have seemed to come in two pieces so you could remove the rear part that covers the screws for the tranny. maybe even the front too (haven't looked that far yet).
Anyway, in general what are you guys doing to keep the "stick" of the protectors when you go to service the vehicle?
The Schelle one comes with 3 small pieces for the rear..
I notched mine for access to the ESC plate screws..
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 11-08-2016, 09:06 AM   #4262
Originally Posted by RCWERKZ View Post
How is the wear on the arms. Anyone have to change them out already?
Any issues? Other and front shock towers?
Just changed mine out - been racing 2X per week since the car came out.
Although the car was still handling great, the slop of the front arms made checking the setup difficult. In the rear, it looks like the pills need to be changed out now, looks like there is more wear on the pills than the arm.
I also changed out all the ball cups - that made things better for about a week and now they are loose again. I come from model airplanes / helicopter background, and we never tolerated the slop you see in these linkages.
I know most of this is minor, but I'm old and need all the set up advantage I can get over the whippersnappers I have to race.
belewis01 is offline   Reply With Quote
Old 11-08-2016, 10:49 AM   #4263
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
servo spacers for a Spektrum 6040? Manual is no help, not that I found anyway. The old manuals would give a run down of which spacer for different brand servos...
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 11-08-2016, 11:57 AM   #4264
tsair's Avatar
Whatever will get the link perfectly straight across laterally with no angle. Same with servo horn ball stud washers.
If you use no spacers, you will have to use shorter mounting screws.
tsair is offline   Reply With Quote
Old 11-08-2016, 12:23 PM   #4265
Mine would not fit onto my savox as well. Strange...
Originally Posted by Riverbluff View Post
I had the exact same problem. It would not fit at all.
crowie03@gmail. is offline   Reply With Quote
Old 11-08-2016, 01:03 PM   #4266
The B5M ball cups don't get any slop for nearly a year. I'm changing mine over this week, as I can't even measure the front camber at this point. My ball cups lasted 3 weeks on the B6.
Eddie_E is offline   Reply With Quote
Old 11-08-2016, 07:30 PM   #4267
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/11/rdrp-b6...ront-axle-set/
RCBuddha is offline   Reply With Quote
Old 11-09-2016, 01:15 AM   #4268
Would someone who owns a B6 (laydown) be able to do me a huge favor?
Could you measure me the exact distance (in mm) between the motor protector brace and the back of the (preferably shorty) servo?
Please state if this is with a shorty or regular servo. Many thanks in advance.
Fearo is offline   Reply With Quote
Old 11-09-2016, 06:22 AM   #4269
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
Whats a popular shorty futaba brand servo people are using?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 11-09-2016, 07:43 AM   #4270
Trader Rating: 19 (100%+)
i'll do it tonight
Associated TC7.1
Associated B6 x2
Associated B64
Associated T5M
Scott R is offline   Reply With Quote
Old 11-09-2016, 07:49 AM   #4271
Originally Posted by Scott R View Post
i'll do it tonight
Thanks so much!
Old 11-09-2016, 08:25 AM   #4272
Front arms
on carpet with a 17mm ride height, the rear of the front arms closest to the bulk head are wearing flat spots from dragging on the carpet (nearest the small 2 x 4mm bhcs that captures the hingpin)
Ball cups
X2- mine have developed considerable slop also. 3 race days, 2 classes, plus 4 practice nights with about 3hrs each night of track time.
Consistent is used in the RC industry as much as Rowdy is used in the mountain bike industry. Truthfully, the only consistent thing is change.
BigChris in PA is offline   Reply With Quote
Old 11-09-2016, 09:12 AM   #4273
soniccj5's Avatar
I've had good luck with the S9551
RC-10/ B4(+8mm)/
B5M FactoryLite|GTB3|Vulcan 17.5|MIP Pucks|Proline Primes|
B64D|510R|6.5 Vulcan
B6D|510R|7.5 Reedy
soniccj5 is offline   Reply With Quote
Old 11-09-2016, 10:16 AM   #4274
Good suggestion and cheap to try out - I think I have some in stock, so it's worth a try at least for the front end.
Old 11-09-2016, 10:21 AM   #4275
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
While the B5 cups have "less" slop, the slop in the b6 cups is very minimal. My car has more than 3 hours of use and has almost no slop. I prefer to avoid the b5 cups, because they are too snug and like to bind up.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Currently Active Users Viewing This Thread: 5 (2 members and 3 guests)
celt, Life_livin
