    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree372Likes
Old 11-06-2016, 02:44 PM   #4216
aeRayls's Avatar
Originally Posted by josh short View Post
Any one running angled ball cups like b5m? They come in newer packs of ball cups
They're in the package so others can upgrade with the newer cups on the B5/T5/SC5
aeRayls is offline   Reply With Quote
Old 11-06-2016, 04:04 PM   #4217
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Originally Posted by Renracer View Post
I see a lot of the team drivers start running the Gull Wing Arms on there B6D what is the adavantage or Disadvantage to these arms over the fault Arms on med to high bite indoor clay tracks
I have recently switched to gullwing as well. Seems to smooth out the steering as well as give the car a bit more on power steering. I'd recommend trying gullwing on any type of med-high bite surface.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 11-06-2016, 04:32 PM   #4218
Twisted check this link out I think Itll help
http://site.petitrc.com/reglages/BuggyBigBoreSpring.pdf
perfect Josh!!
Jeff Check
twistedneck is offline   Reply With Quote
Old 11-06-2016, 05:46 PM   #4219
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Originally Posted by twistedneck View Post
I am using Yokomo Green front and rear springs on my B6D for indoor clay track.. they are super plush but I don't know how they compare to the factory Associated B6D setup. Does anyone know what the Yokomo numbers mean? How they compare to Associated rates?
My current setup:
yokomo front green - 775
yokomo rear green - 1200
B6D factory setup:
associated white front - 3.3 lbs/in
associated green rear - 2.0 lbs /in
This chart was done using a GForce spring tester, the numbers may not be 100% but the comparison is
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 11-06-2016, 07:31 PM   #4220
I haven't seen these setups, are you guys changing towers and arms or doing a mix of B6D tower with B6 arms??
Tijuana_Taxi is offline   Reply With Quote
Old 11-07-2016, 06:41 AM   #4221
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Wide tower corresponds to the gull arms and narrow tower to the flat arms.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 11-07-2016, 06:53 AM   #4222
"Smiley"'s Avatar
For gullwing, you have to use the gullwing tower and arms together. A good base setup for gullwing is Cole Tollards setup under the B6 setups on the AE site.
Old 11-07-2016, 07:28 AM   #4223
TAMAK's Avatar
Trader Rating: 28 (100%+)
Guys are also putting a 1mm spacer between the bulkhead and the chassis to further enhance the gullwing (lower?) roll center setup on dirt. This is what majority of people were doing at the Associated race.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-07-2016, 11:53 AM   #4224
Eli
Eli's Avatar
Are you saying they were running both the spacers to lower the bulkhead and the gull wing setup?
Eli Westrup - SDRC Raceway
Eli is offline   Reply With Quote
Old 11-07-2016, 12:59 PM   #4225
Razathorn's Avatar
Man guys, I gotta say, my b6d with long shocks and KIT setup is just super amazing. You may or may not know but I'm the "setup guy" that just always changes stuff and posts setups up, but honestly, I have no asks from this car other than to keep being amazing. First week out, car was a little "tame" for my tastes, but I came back out with some re-foamed fronts and it was amazing. Was able to win one A main and get a 2nd this week with it against some pretty stout competition.
I was a huge "boooo associated" for releasing the b6 so soon after the b5m, but this car is a total about face for AE. Kit setup was money. Fit and finish was on. Nothing wrong with the kit. Literally trimmed the body 1 hour prior to the first race and got one practice run and was competitive.
I honestly can't say enough good things about it. Can't wait for the next 4wheel.
Wayne
freezeframe007 likes this.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 11-07-2016, 01:17 PM   #4226
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Wayne
Yeah, the car is really really good. I still have a B5m, but this car is so much better in many many ways.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-07-2016, 01:36 PM   #4227
Eli
Eli's Avatar
Wayne
What is the track surface you run on? Just curious. I should have mine built and maybe racing by this Wednesday.
Old 11-07-2016, 01:44 PM   #4228
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
+1 curious as well.
For those with the long rear tower and use it on carpet, anything you recommend for changes due to the tower?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 11-07-2016, 02:51 PM   #4229
Andrew Selvaggi's Avatar
On all conditions, if the grip is super low and you need to tune some oversteer out of the car you can go to .5mm shims.
Team Associated ~ JConcepts ~ Hobby Wing ~ Team Orion ~ nVision ~ Sav÷x ~ Upgrade RC
Andrew Selvaggi is offline   Reply With Quote
Old 11-07-2016, 03:01 PM   #4230
Razathorn's Avatar
Originally Posted by Cain View Post
+1 curious as well.
I'm on a moist packed black topsoil track that acts very similar to clay in terms of traction. I would say it's less traction than a high bite clay for sure, but we've been running m4 or clay slicks on it or scrubbed in electrons / or microns etc. Here's a video of me driving my 17.5 RC10 worlds car rerelease on it a couple of weeks back. B6 is for mod, which is good, because the worlds car would wheelie itself into oblivion with much more than a 17.5—it's a trip to drive with a ton of grip.
+ YouTube Video
