    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree323Likes
Old 11-04-2016, 12:14 AM   #4186
Originally Posted by Matt Trimmings View Post
Get the aluminum d mount and practice.
That didn't answer my question...? I already have this as stated in my post.
raym5590 is offline   Reply With Quote
Old 11-04-2016, 12:44 AM   #4187
abailey21's Avatar
Trader Rating: 36 (100%+)
It does answer your question dude
Thats the only piece you really need. The car doesn't need $1000 in hop ups, if you break something venture into upgrading that part at that time.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 11-04-2016, 05:28 AM   #4188
Trader Rating: 19 (100%+)
Originally Posted by Phillip F View Post
My b6 jumps nose high even with brakes punched when I leave the face of the jump. Should I add that 36g steel weight under the servo or use the 30g front brass bulkhead?
make sure your front shocks aren't rebounding too quickly, either from too light of a oil, too large holes in your pistons, or too stiff springs, or combination of all 3 . I say this because you say you're nailing the brakes which transfers the weight to the front end, if it's rebounding too quickly it'll still go nose up no matter what you do.
Associated TC7.1
Associated B6 x2
Associated B64
Associated T5M
Scott R is offline   Reply With Quote
Old 11-04-2016, 06:13 AM   #4189
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
Originally Posted by abailey21 View Post
... The car doesn't need $1000 in hop ups, if you break something venture into upgrading that part at that time.
+1 from what I am reading.
If you do want another item you could look into, the only thing that at least for me I am kind of looking more into are the towers from VRP.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 11-04-2016, 06:46 AM   #4190
For B6 17.5 stock class, what if any weight are people running and where on the car for turf/carpet racing? I'm currently just running the brass front bulkhead.
Phugazi is offline   Reply With Quote
Old 11-04-2016, 07:38 AM   #4191
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You may want to go re-read what you typed. The Aluminum D mount is NOT listed.
ASC91688
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 11-04-2016, 08:59 AM   #4192
ASC91688
The car comes with the aluminum D mount already... Not sure if you were trying to be sarcastic, also the brass hinge pin holder is what I was referring to as the D mount.
Old 11-04-2016, 09:03 AM   #4193
Trader Rating: 8 (90%+)
Comes with aluminum c mount. Aluminum d mount gives you ample tuning options with regard to roll center, toe, anti-squat and width. Stock d mount leaves you limited in this regard.
Johnny Carey is offline   Reply With Quote
Old 11-04-2016, 09:05 AM   #4194
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
No it doesn't.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 11-04-2016, 09:41 AM   #4195
either way I need the brass D mount for the weight.
As I'm looking over this all I realize this whole time I'm talking about the brass c mount
Old 11-04-2016, 09:46 AM   #4196
Super Moderator
No worries...Either the Brass or Aluminum D mount will allow you make many more adjustments in comparison to the stock plastic piece.
Old 11-04-2016, 09:56 AM   #4197
I will be picking that up today, thank you sir.
Old 11-04-2016, 10:03 AM   #4198
goehm's Avatar
Trader Rating: 44 (100%+)
Lots of peeing in cornflakes today!
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 11-04-2016, 11:16 AM   #4199
abailey21's Avatar
Tastes like Friday
And to be fair, I wrote that after working overnight for 12 hours
K.C.C.O.
Old 11-04-2016, 12:56 PM   #4200
AccessRacer's Avatar
Trader Rating: 20 (100%+)
How many guys out there like be 31 millimeter long rear shocks versus the stock length shocks and why?
AccessRacer is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
