    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 11-03-2016, 09:14 AM   #4171
goehm's Avatar
Trader Rating: 44 (100%+)
Originally Posted by BigChris in PA View Post
Post 4137 looks like it got overlooked.
Roger that. I wouldn't say overlooked, it just isn't well connected to the discussion regarding the issue you experienced.
Reply with history, or some sort of reference helps resolve that since these threads all basically are read in linear form.
(IE: If I didn't include the quote, would anyone know what I'm even talking about?)
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 11-03-2016, 10:20 AM   #4172
Okay so sorry if this has been asked before but I have just got my b6d. I want to know what hop ups should I be prioritizing, I run on a med-high bite clay track.
Current hop ups I have are
25g brass hinge pin holder
Exotek slipper eliminator
Kashima shocks
Lay down transmission
Aluminum bulkhead
raym5590 is offline   Reply With Quote
Old 11-03-2016, 10:35 AM   #4173
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Get the aluminum d mount and practice.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 11-03-2016, 10:51 AM   #4174
Mason's Avatar
Originally Posted by DDTG View Post
I have the type 1 Ackerman arms from schelle. I do not have his shock tower or front wing. I have the standard ae gull wing tower/hard arms. I believe it's a proline front wing I am running.
Would the tower make that big of a difference? Isn't it just thicker for better durability?
the alum steering rack?
you say it has great mid to exit. but pushes? is this going into the corner then or??
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 11-03-2016, 03:35 PM   #4175
Default B6 loose set up
Does anyone have a good base setup for the B6 on a indoor sports hall floor with a bit of carpet, low traction.
Cheers
450kid is offline   Reply With Quote
Old 11-03-2016, 04:41 PM   #4176
tsair's Avatar
IIRC, the gullwing arms and tower are for high bite/carpet according to Brent, and meant to "smooth out" the steering. Which is RC speak for "less". 😄
I'd definitely try out flat arms and flat tower.
tsair is offline   Reply With Quote
Old 11-03-2016, 05:23 PM   #4177
Trader Rating: 22 (100%+)
I am looking for some set up help. I have a really bad push and the car doesn't feel direct at all like other b6 I have driven. I have tried a few different setups and gone through the car to make sure there is no binding in suspension or driveline. I have the correct tires for the track and have even tried the fast guys tires to make sure. It is great mid to exit but still has a lot of push.
I can't post the link to the setup but it is the Kurt wenger ocrc 9/21.
The only change I made is the rear shocks in the middle hole on the tower.
Any ideas of what to try next?
That's a lot of optional parts on that setup. Do you have all of them? If not, it's hard to compare apples to apples on that. If you do have everything that's listed on that setup, I have to agree, your diff has to be too tight, because I can't see what would cause your car to push on exit with that setup.
joncmack is offline   Reply With Quote
Old 11-03-2016, 05:34 PM   #4178
sport10's Avatar
Sounds like he is talking about corner entry to me not exit according to his posts. I would say add 1 to 2mm of washer under the steering ballstud to change the ackerman and maybe make sure you have a total of 30 degrees front kickup. The more kickup you have the usually the better on corner entry. Also, using part of a published setup is not a good thing. It is better to work up your own setup as your track is probably different. If you cant make that setup work I would suggest returning to the kit setup and restarting from there.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 11-03-2016, 05:55 PM   #4179
Trader Rating: 32 (100%+)
Question guys i have b6d can i use rb6.6 front and shocks? coz i really kyosho shocks than AE.
raved007 is offline   Reply With Quote
Old 11-03-2016, 06:09 PM   #4180
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Sure.
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 11-03-2016, 06:12 PM   #4181
Phillip F's Avatar
Trader Rating: 15 (100%+)
My b6 jumps nose high even with brakes punched when I leave the face of the jump. Should I add that 36g steel weight under the servo or use the 30g front brass bulkhead?
Phillip F is offline   Reply With Quote
Old 11-03-2016, 07:47 PM   #4182
Andrew Selvaggi's Avatar
Morning/Afternoon/Evening everyone!
With the upcoming Outdoor Reedy Race Of Champions at HRH in a couple weeks, a fair chunk of the AE AUS team are coming over to have some fun. Outdoor low to medium grip is the surface we race on pretty much all year round. We've worked really hard on developing the B6d over the last few months since it's release.
In preparation for the Reedy race I have done a blog/Aussie build on a B6d, with a combination of photos, videos and in depth descriptions.
Please feel free to hit me up if you have any questions, and hopefully I'll get to meet some of you guys over there.
https://aussiebuilds.wordpress.com/2...sie-b6d-build/
Team Associated ~ JConcepts ~ Hobby Wing ~ Team Orion ~ nVision ~ Sav÷x ~ Upgrade RC
Andrew Selvaggi is offline   Reply With Quote
Old 11-03-2016, 08:59 PM   #4183
tsair's Avatar
That sounds unusual. What radio are you using?
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
Old 11-03-2016, 09:08 PM   #4184
Phillip F's Avatar
Futaba 4PLS with the R204GF-E receiver
Old 11-03-2016, 10:18 PM   #4185
Phillip F's Avatar
thank you for the tips...applying some of it right now in my B6 and B5M.
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
HeavyD99
