    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree327Likes
Old 11-02-2016, 10:08 AM   #4156
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Johnn27 View Post
who makes those cf hub links ??
Look for JL Breathless Racing on FB. Some local makes them.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-02-2016, 05:54 PM   #4157
I am looking for some set up help. I have a really bad push and the car doesn't feel direct at all like other b6 I have driven. I have tried a few different setups and gone through the car to make sure there is no binding in suspension or driveline. I have the correct tires for the track and have even tried the fast guys tires to make sure. It is great mid to exit but still has a lot of push.
I can't post the link to the setup but it is the Kurt wenger ocrc 9/21.
The only change I made is the rear shocks in the middle hole on the tower.
Any ideas of what to try next?
DDTG is offline   Reply With Quote
Old 11-02-2016, 07:06 PM   #4158
tsair's Avatar
Your diff could be tighter than the other guys.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 11-02-2016, 07:23 PM   #4159
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Redworkshop makes them now...
https://www.facebook.com/redworkshopracing/?fref=ts
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 11-02-2016, 09:03 PM   #4160
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/10/rdrp-b6...ing-stiffener/
http://www.redrc.net/2016/11/schelle...e-guard-combo/
RCBuddha is offline   Reply With Quote
Old 11-02-2016, 09:08 PM   #4161
Thrifty's Avatar
So, I assume this gets rid of the steering assembly's slop?.. I've yet to actually run mine but I can make a good 5degree of slop with it on the stand..
Thrifty is offline   Reply With Quote
Old 11-02-2016, 09:18 PM   #4162
RCBuddha's Avatar
Default and because i like tools...
http://www.visionracingproducts.com/...ck-VRP1254.htm
Old 11-02-2016, 11:23 PM   #4163
Eli
Eli's Avatar
That shock stand is sexy Buddha but I wish there was another set of holes for the shock caps like the old school ofna shock stand which I currently keep on my pit table at home.
Eli is offline   Reply With Quote
Old 11-02-2016, 11:49 PM   #4164
JAE
Trader Rating: 28 (100%+)
I had the same issue. To the tee. Same setup. Only difference was I had VRP piStons in. I believe I had missed a washer on top of a piston but shocks seemed to work fine. Threw some old b5 kashima shocks on it as a last resort. Worked like a charm. Push gone. It was either the mistake on the piston. Or, I'm beginning it may have been by switching the shocks the front piston was a 1.6 2 hole vs the 3 hole front piston. My 2 cents. It was probably my mistake on the internals of the shock/piston installation. But, Like you I Had tried everything and couldnt figure it out. It was definitely isolated to suspension though..bathe buggy just has too much steering to push like this
QUOTE=DDTG;14723827]I am looking for some set up help. I have a really bad push and the car doesn't feel direct at all like other b6 I have driven. I have tried a few different setups and gone through the car to make sure there is no binding in suspension or driveline. I have the correct tires for the track and have even tried the fast guys tires to make sure. It is great mid to exit but still has a lot of push.
Any ideas of what to try next?[/QUOTE]
JAE is offline   Reply With Quote
Old 11-03-2016, 05:52 AM   #4165
Mason's Avatar
you are running all the schelle parts on the front end?
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 11-03-2016, 06:21 AM   #4166
I have the type 1 Ackerman arms from schelle. I do not have his shock tower or front wing. I have the standard ae gull wing tower/hard arms. I believe it's a proline front wing I am running.
Would the tower make that big of a difference? Isn't it just thicker for better durability?
Old 11-03-2016, 06:22 AM   #4167
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
for the whole spur gear guards, what currently appears to be best solution or does getting the Jconcepts S2 body take care of that issue?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 11-03-2016, 06:38 AM   #4168
I only has issues with the spur rubbing with mod spurs
Old 11-03-2016, 06:47 AM   #4169
Are the kashima shocks worth the upgrade?
Support your local track!!
rpc07 is offline   Reply With Quote
Old 11-03-2016, 06:52 AM   #4170
IMO...not really
But....If you plan to run the b5 rear shock bodies....they have been discontinued in NON-Kashima....so you will be forced to get them.....and you will want matching fronts....
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
Allen Drebi
