    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree368Likes
Old 10-29-2016, 11:26 PM   #4081
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by motoman811 View Post
what would be the benefit of running TLR 22 3. rear hubs on the b6
To make this months fail compilation?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-30-2016, 12:41 AM   #4082
Trader Rating: 18 (100%+)
Originally Posted by HK500Pilot View Post
Can someone give me some advice on a wheel and tire combo to start out with for racing on a carpet track? What is the advantage of running the 61mm wheel that Associated lists in the manual?
Thanks for the help!
If your track allows them get some foams from Gone Bananas or make your own.
Awesomatix A800XA - Xray XB2 2018
iTz Nicholas72 is offline   Reply With Quote
Old 10-30-2016, 01:53 AM   #4083
JAE
Trader Rating: 28 (100%+)
Hanger Pill adjustment: left mine kit middle middle. When tuning roll center, am I correct in my assumption that pointing the pins downward lowers roll center (same as more shims on rear tower camber link)? And pointing up is raising roll center (eliminating shims from camber link)?. Already set on anti squat, toe and track width just want to make sure I've got this right. Also, what makes this adjustment different from adjust roll center at the inner camber link mount? Thx all
JAE is offline   Reply With Quote
Old 10-30-2016, 07:48 AM   #4084
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Informal survey:
How many of you actually use the links to the aftermarket parts on the front page?
I don't mind updating, but I'm starting to wonder how useful people find it...Let me know....
RCBuddha is offline   Reply With Quote
Old 10-30-2016, 07:55 AM   #4085
Thrifty's Avatar
Very useful. Pretty sure most people check them out when first getting the buggy to decide on which hopups to get.
After getting their ride to their liking maybe check back every so often to see if anything new has shown up..
I've personally checked them out.
Thrifty is offline   Reply With Quote
Old 10-30-2016, 08:05 AM   #4086
tony montana's Avatar
Trader Rating: 65 (100%+)
I use it as well. Great job on it by the way
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 10-30-2016, 08:51 AM   #4087
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
+1 I use it. very helpful.
If there was a way to post a mini review of things that we know have a known issue with it to watch for that would be cool.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 10-30-2016, 11:59 AM   #4088
eper's Avatar
Trader Rating: 14 (100%+)
when guys are running the 1mm front bulkhead shim are u guys chaging droop settings or leaving them the same?
eper is offline   Reply With Quote
Old 10-30-2016, 12:28 PM   #4089
Trader Rating: 488 (100%+)
Originally Posted by RCBuddha View Post
Informal survey:
I've used them....
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 10-30-2016, 01:41 PM   #4090
vabroom's Avatar
Informal survey:
I use it to compare parts
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 10-30-2016, 02:08 PM   #4091
Woulvesbaine's Avatar
Informal survey:
I love it. I often check back to see if there's anything new.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 10-30-2016, 02:11 PM   #4092
Eli
Eli's Avatar
Informal survey:
I've used them several times, very useful and appreciative of it.
Eli is offline   Reply With Quote
Old 10-30-2016, 02:12 PM   #4093
Thrifty's Avatar
Maybe you can help me out here.. I'm coming from a 1:8th buggy and don't see where to change droop on this guy..
different setup in some ways here...
Old 10-30-2016, 02:19 PM   #4094
1/4milecrazy's Avatar
Internal spacers in shocks. Or unscrew the the lower shock eye.
Apparently "equal" and "partners" means different things to different people.
1/4milecrazy is online now   Reply With Quote
Old 10-30-2016, 02:27 PM   #4095
Thrifty's Avatar
I saw a couple of those spacer when I rebuilt the shocks. Never saw that before. (Bought it previously owned).
Still clueless on how to actually do it though.. I'm sure it's super simple once I get it though.. will poke around some more when I get home.
Currently Active Users Viewing This Thread: 10 (4 members and 6 guests)
Be6, Cruzin2020, trick25, windellmc
