Team Associated B6 & B6D thread
#4041
#4042
i have took my slipper lock out off even on high bite. maybe if ur track dont have a lot of 180's it might be ok but with my monster trinity hp seems to break loose with a slipper delete. spend that 12 bucks on some tires.
#4044
Are you guys raising/lowering your ride heights when changing tires? For example, my Electrons are about 1-2mm radius bigger than my slicks. When I slap on the Electrons, lowering the ride height 1mm produces a bunch of unwanted effects (camber angles, camber link geometry, etc.) that would be a pain to re-sort.
Doing some testing, it seems better to just leave the car untouched, which means you are driving at different ride heights, depending on the tire.
#4045
#4046
In other words, you can't just adjust your shock collars to get the same ride height when switching tires. Theoretically you need to re-adjust everything, including camber links, ballstud heights, etc. to get the same (relative) roll centers, etc.
If you extrapolate to an extreme case -- let's say you set your ride height to 23mm and then use a 3mm bigger radius tire -- you can't just drop your car 3mm to compensate, this would be a huge change to everything. Your arm angles would be too low, you would be in a different part of the spring travel, your camber links would be more angled, etc.
Anyways, just something I noticed. On the B6, 1mm ride height makes such a huge difference, probably mostly because the geometry of everything changes. In my opinion, this is why AE provided axle height adjustments in the B6 -- if you want to change ride heights, you can also compensate in the axle heights to keep the geometry of everything the same.
#4048
But then you're affecting camber, roll centers, etc.
Forget about it. Adjust ride height and go fast. I have been doing good with my B6D with the kit set up, laydown transmission and brass C Block. The track changes all the time anyway.
#4049
Was trying to figure out why, and had never heard of this idea before. Most people are just like "dude, you GOTTA be at 23/18/30mm no matter what!".
